Question about Lakewood 200I Floor / Box Fan
How to stop squeaking noise - Lakewood 200I Floor / Box Fan
  • 576 Answers
Some light machine oil (sewing machine oil works well) where the shaft goes through the motor (on both ends, if accessible) should help. you may need to take the grates off of it to reach the oiling points. (Unplug it first, of course)
Posted on Mar 26, 2010
SOURCE:
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
Makes squealing noise when stopped
check your belts for cracks replace if cracked or not plyable
Sep 15, 2013 | Pontiac Cars & Trucks
I have a squeaking noise coming from the rear of my 06 range rover hse what could it be
Rear suspension bushings will squeak, Dealers will want to replace them all, Give them a good soaking with a rubber lubricant and they will stop making noise, I use Ruglyde, it is a rubber lubricant for mounting tires and works very well for this squeak
Dec 11, 2012 | Land Rover Range Rover Cars & Trucks
2010 electra glide ultra classic, squeaking noise from primary side only when riding. Could clutch or, belt be the problem. Clutch engages smoothly with no acceleration problems. Especially noticeable on...
You need to determine whether the squeaking is being made by the engine, the primary, the drive, or the frame. While riding, pull in the clutch, does the squeaking stop or change in any manner? Is the noise there when the engine is running but standing still? Pull the clutch lever in and release, does the squeak change or stop.
If I had to say what I think it is, I'd say it's probably the rear drive belt is not tracking correctly due to the alignment of the rear wheel. Look at the rear wheel adjusters. They should be exactly the same on either side of the swingarm. Also, the belt must be tight. If not, a loose belt will make a squeaking noise.
Good Luck
Steve
Dec 26, 2010 | Harley Davidson FLHTCUI Electra Glide...
Dryer making load squeaking and squealing noise when starting it up..sometime it stops after awhile,but now it does it all the time.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
eue
Jan 22, 2010 | Maytag MDE508DA Dryer
Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Aug 04, 2009 | Exercise & Fitness
HOW DO YOU GET THE SQUEAKING NOISE TO STOP
You must indicate where the squeaking is coming from. If its only squeaking, move on. There's other people here with down time problems. It'll stop squeaking or stop running eventually. If it stops working, then write in!
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Squeaking
the squeak is coming from the drum unit. If you take out the drum and rotate it by hand it will most likely give you the same noise. you may be able to stop it by pouring some toner on it, but in reality it is more annoying than a problem.
there is a blade that scrapes off excess toner from the drum, it is slightly dry and causes the squeaking, technicians usually use a special powder that looks like baby powder to "lubricate" the blade, and stop the noise.
Aug 11, 2008 | Canon PC1061 Copier
Lakewood 200I Floor / Box Fan Logo
212 people viewed this question
Top Lakewood Dryers Experts
Bruce Showalter
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
