Question about E-Machines eMachines Desktop PC
Where can I get a replacement motherboard for emachine T2984?
Where can I get a replacement motherboard for emachine T2984.
My computer won't boot up and the techie stated that the motherboard had to be replaced. I want to do this myself to save cost.
But I don't know what to look for online. Please help?
  • ljbltd Mar 12, 2008
    Thank you for the reply.
    Is this compatible with my T2984?
    Problem Solver:
  • 8 Answers
Here is a site where you can buy one for a relatively good price....hope it works out.
Posted on Mar 12, 2008
SOURCE:
E-machine T2984 Motherboard replacement
The eMachines T2984 uses an Intel D845GVSR motherboard,
http://www.ebay.com/itm/Intel-D845GVSR-Socket-478-Motherboard-Warranty-/261132348848?pt=Motherboards&hash=item3cccb36db0
Just one example from a quick search.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
The above is the motherboard manual -
Intel Desktop Board D845GVSR Product Guide (PDF)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Computers & Internet
Hello, my emachines e4259 shutts down after boot up., i tried to install another version of vista but itts still stutting down in install program. what can it be?
If it is physically shutting off (like someone yanked the power cord) than it is a power supply
If the computers screen goes black, but the computer still runs, it could be RAM or a motherboard failure
May 24, 2011 | E-Machines eMachines Refurbished EMA...
IM connecting a OKIA LC-8460BTX POWER SUPPLY TO MY EMACHINES T2984. I cannt figure out where the wires are placed.
There should be a photo of the board and instruction on where the leads are fitted if you browse the manufacturers web site and input the model of the unit you are refitting.
I have found this site, which may be of use to you. Regards.
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/302350-e-machine-t2984-motherboard.html
Jan 04, 2011 | E-Machines eMachines Refurbished EMA...
Computer won't boot up/// turn on///monitor is blank
check the main power cord that plugs into the wall socket. try a known good power cord. Also, try holding the power button down for 10 seconds and try to power it back up.
Jan 21, 2010 | E-Machines eMachines Refurbished EMA...
Cant boot my emachine 2984
Did you check the CMOS battery and the CPU fan. Those are two things that if aren't working the way they should be, then some computers will not boot up. Try this first then post a response if you still can't get it working.
Sep 01, 2009 | E-Machines eMachines Refurbished EMA...
Windows want start!!
Remeber that Vista OEM is activated with your harware and if you change it so much it will deactivate with your licence.
press F6 at boot to have the options like "boot with system critical drivers only without LAN" and see if it boots this way, then uninstall all drivers and reboot, install the drivers for the new motherboard.
If this doesn't work you might need to reinstall Win and I'm pretty sure you won't be able to activate it because the hardware key has changed.
Feb 19, 2009 | E-Machines eMachines Refurbished EMA...
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
VGA/MOTHERBOARD
yep. try disable on board card (if there is a setting) and use external video card.
Jan 08, 2008 | E-Machines eMachines Refurbished EMA...
Motherboard manuel
i need manual for motherboard 14319 imperial_gv 20030812 thankz
Dec 25, 2007 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
420 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
