Question about Samsung Prostar 816 Phone
Day night ringing problem
Somehow the speaker light is continuously blinking, and we are not sure what was programmed
Try #12 when the phone is hooked on handset, push your station button ,then # again
Posted on Mar 13, 2008
When in night mode, how do I make the samsung idcs 18d ring on every extension
if you know your password for your phone system do this. enter programming mode by pressing transfer key, type 800 enter your password then volume up key then speaker key. go to program 601 station groups find unused station group ie 510. make this group unconditional and under members add all thr extensions you want to ring then press speaker key. then go to program 406. enter line number of line and under night mode tell it the station group number you programmed above
May 07, 2014 | Samsung Falcon iDCS 18D Display Phone with...
Lights are blinking and dont rest
Do you means Laptop Hard Disk light?
If lights are blinking it simply mean there are activities of reading and writing on the hard disk, simply saying is there are background program working day and night, you should see what is the programs, mostly will be Anti Virus which doing scanning job.
Feb 17, 2013 | Computers & Internet
My phone flashes all the time, and gives me an indication that I have a message. There is no message, and it continues to blink, even after it is supposedly cleared out.
My message light is lit SOLID and only follows the ring, so you must be talking about the FWD/DND light.
The Forward condition can be cleared, but you will lose the call forwarding to voice mail. The light can be programmed by your installer to be solid, instead of flashing, but the installer will have to do that.
If you're somehow oddly talking about the message indicator on the upper right of the phone which doesn't flash, them press MESSAGE and look at the display. It will tell you where the message came from and let you press CLEAR to erase it.
Sep 02, 2010 | Panasonic KX-T7633 Corded Phone
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Speaker not working
More then likey you will have to perform a master reset to the device
Feb 02, 2009 | HTC G1
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Feb 21, 2008 | Samsung Prostar 816 Phone
Blue light
Press the mute/program button, then press the caller ID-volume button to select handset setup (then press mute/program again to select this option). Next press tye caller ID-volume until you get to Default settings (its the last setting so pressing the up arrow is the fastest way to it). Press the mute/program button again to select the option. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
The first time I did this it didn't work, so I did again and toward the end of the steps above the phone beeped at me and stated "Reset Default Settings" (or something like that) then time I hit the mute/program button again and everything worked great. I think that last beep maybe have been a are you sure you want to restore to default question.
Remember tis will erase any custome settings you made on the phone (ring tones, ring volume, memory, etc.)
Jan 31, 2008 | GE 28111 Cordless Phone
Lands Phones Logo
42 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
