Question about Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
I just recieve tv from friend worked for a day , no picture but can hear sound
  • olie1986 Mar 13, 2008
    thanks solder ic401 pins tv is ok
  • Mitsubishi Master
  • 8,617 Answers
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Posted on Mar 12, 2008
  • Sonny Berry
    Sonny Berry Mar 13, 2008
    I figured thats what it was. Common fault with that model when the tubes blank out. Glad I could help you out and thanks for the rating.
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
Dan
May 04, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
No picture but has blue green and red light down middle and sound
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 28, 2008 | Panasonic PT-51HX43 51" Rear Projection...
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Red, blue and green vertical lines in middle of screen all functions are ok
tibs?? what are tubs?? Your problem is a convergence problem. there are two stk###-### you have to have a TV repair person relace for you . there may be some touch up alighnment needed also when IC's are replaced. Good Luck
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
Mitsubishi WS-48315 48" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
