Question about Technics Audio Players & Recorders
Technics CD multichanger, model SL-MC410
I have a Technics CD multichanger, model SL-MC410. I have plugged it in and the red standby light is on. I have pushed the power button on and pushed the power button on the remote. The unit does not switch on. The batteries are new in the remote, I have checked them. I have put cd's in the unit.
Does anyone have any idea's as to what the problem could be?
Your help would be apreciated! Thanks.
  • 4234 Answers
SOURCE: My Technics SL-DV290 stereo has
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Posted on Apr 02, 2008
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
JULIANFIX
  • 975 Answers
SOURCE: dead
IT COULD BE A FUSE , needs to be replace , if your handy , you can do it yourself , open unit , and check where the power supply is .look for a tiny glass tube type fuse , replace , and try again , hope this helps , please rate , AJ
Posted on May 07, 2008
dunnbiker
  • 8546 Answers
SOURCE: Equalizer for Bose 901 Series IV
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's attached as you have them will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization and for another, if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devises for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what I think you're trying to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). Yours does NOT so we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious place would be at one of the few OUTputs on the back, assuming you have one free to use.
I see Video 1 and MD/Tape have Audio Outputs. Use one of these to feed the Bose EQ. **
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Sony STR-DE595 (Video 1 or MD/Tape Audio Out ***) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** In either case you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. This is what's happening to you right now when you select MD/Tape. You're disconnecting the source from the 901 EQ.
You may have to get ugly with your other input components to find them all homes on the receiver. The labeling won't necessarily match up with the device types. Mine is ugly like that and I have a lot of connectors, but I have even more input devices.
If you have CD, TV Cable box and DVD (typical) you need to assess what you have that is digital and use what you can wherever you can, then the leftover analog device(s) - PC? - can go into any available analog input that is left over.
Whichever of these connections you DO NOT use for the 901's will still be available for using some kind of conventional analog recording device or sound processor such as an EQ or dbx Expander. However, as with any digital receiver, selection of that device for monitoring will kill the sound from any DIGITAL source you have playing (or maybe it just won't allow you to monitor).
Posted on Apr 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
NEED A BELT FOR TECHNICS DISC CHANGER MODEL NUMBER SL-MC400
take the belt to your local ace hardware and look for an o-ring that is slightly smaller than the stretched out belt. this will work just as well.
Mar 01, 2015 | Technics SL-MC400 110-Disc CD Changer
Technics sl mc410
The Optical Pickup(laser) has worn out. When you place a disc in the drawer, it has to load and read the TOC(table of contacts) if if can't read that, it assumes there is no CD in the drawer and stops or ejects.
Aug 28, 2014 | Technics Audio Players & Recorders
TECHNICS SL HD81 5 CD MULTICHANGER. The multichanger, when a disc is put into any of the five slots, doesn't sound like the disc spins - almost as soon as the draw is closed, NO DISC appears on th
The motor is shot,Or the gears are jamming up in it, Just look for a different one, It will cost you more to have it repaired, I have got good used disc (Players) For $10 to $40 at the most for friends of mine,
Nov 04, 2012 | Technics Audio Players & Recorders
Tech SL-MC410. Continously displays "Checking Disc"
When the unit is saying "Checking discs" and neither goes further nor turns off (just says "Off" but doesn't), the reason is still the main belt (accessible from the top as soon as you lift the cover) that is too loose. When the belt is way too loose, the unit doesn't move at all, if the belt is little too loose, the player-unit will move a bit, but there is not enough torque on the gears to reach the end position (where the player unit is secured against movements).
May 07, 2012 | Technics SL-MC400 110-Disc CD Changer
175 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
