How do i get the rear door open when the latch handle is broken?
Take the plastic cover off from the inside. Fairly easy, a few bolts and some plastic clips holding it on. You may be able to open it from the outside but you'll have to take the inside cover off to replace the handle anyway. This is a common problem and if you need more detailed instructions just do a search on the net.
SOURCE: The latch handle does not
I would pop off the rear hatch trim to look inside to see what is broken. Usually there are a bunch of push pins that hold the trim in place.
