Question about Sony PlayStation 2 (PS2) Console
PS2 Fan problem
Opened my ps2 to clean out, when i reassembled it i stupidly managed to cut the fan wire with the casing *****, i tried reattaching the wires but the fan would not work so i bought another fan (2nd hand) plugged in still not working, how can i test this fan and also i have read that a fuse can be replaced which one and where is it situated.
  • 149 Answers
The fuse is next to the fan connection
Posted on Mar 19, 2008
SOURCE:
My ps2 shutdown while i'm playing, i can't open it anymore. why?
It might be overheating. The most common problem is the fan. Try spraying pressured air to clean it, or bring it to a shop to change the fan.
Mar 06, 2011 | Sony PlayStation 2 (PS2) Console
Need to clean my ps2
To Clean you PS2 Here are the steps
1. Unscrew you PS2 bye the top
2. Get a duster air can to spray off the dust. (make sure you don't spray to much they might have gas in them.)
3. Take a two sided Q tip or one sided doesn't matter and dip the cotton sides into rubbing alcohol and careful clean of the lens do not scratch it or you ruin your PS2.
4. Take all peices that you might have moved and put the exactly in place.
5. Put cover on.
6. Screw the screws back in (P.S. do not use a electric powered screw driver use a hand held one.)
7. Turn on and test it if it has problems like heating up dust out the fan on the back.
8. Enjoy. <(^ . ^)>
And, if you have a small PS2 even thought they are junk just dust out the fan open the part that you put the disc in and dust arond the lens and inside and then just clean the lens with the Q tip and alcohol.
YOUR WELCOME
Apr 26, 2009 | Video Game Consoles & Games
Fan issues
probably that the fan wires are cut of, you can try and fix this your self but it wuld be best to take it to someone who is qualified. Unles that you are.
Nov 11, 2008 | Sony PlayStation 2 (PS2) Console
Black screen, no disc spin or eject, fan spins
That same thing happened to me. I disassembled the ps2 to find out the problem, I found out. If your console does not turn on or no lights check the silver ribbin connected to the reset button. See If it is in all the way the top and the bottom of the ribbin or check to see if there are any tares in it if there is replace it . You can get good parts off of Ebay.
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Cooling Fan not spinning
well could just be shot fans are not suppose to last forever the best thing to do would be replace the fan, make sure that the fan is not plugged up with anything and it has free movement when spinning if it struggles any then its seized up which would have to be replaced measure the fan and take a look on ebay for a replacement fan of that size but if you search for ps2 fan replacement then chances are that it will cost alot more.
if you need help finding a replacement let me know im more then willing to help out.
good luck
Oct 03, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 not spinning and light turning green then back to red
Hi
Your PS2 is probably experiencing a short circuit on the motherboard or the Emotion Engine is burned up. Sometimes the fan goes dead and the PS2 overheats and shuts down showing the red light. You can open the PS2 and clean up the motherboard and maybe it will recover.
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
Problem with ps2 slime line
where is the AOSS button on the button
Dec 05, 2007 | Microsoft Xbox 360 Console
Playstaion lens
Hi Jewelbaby, Sounds like your fan is not working properly or your PS2 is clogged with lint and dust. if your skilled, you can open and disassemble the entire PS2 with power off of course, and clean it of dust and lint completely. Test the Fan. if youor not comfortable doing this The playstation Clinic can help you get your PS2 in top not and better than new for less than $45 including shipping costs. See us at www.playstationclinic.com
Sep 25, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 doesn't read the game. what should i do?
It likely needs a cleaning. A PROFESSIONAL cleaning, not a lens disc.... There isa a slim chance ther laser is dead, but it's more likely just the cleaning. Rates vary, but my shop charges about $56 for PS2 cleanings (we actually clean inside the optical assembly and mechanisms and reallign eveything back to spec).
Sep 22, 2007 | Sony PlayStation 2 (PS2) Console
PS2 turns on fine when disk tray is open but the reset button turns red from green and stops working
Here's a pretty good guess what happened... All of the Windex products are mostly water. You probably got some of the Windex onto the board of the PS2. Now this isn't a problem until it is energized. Once you turned it on, the windex which is mostly water probably shorted out your board instantly. There are a few things you can try though. Open up your console and try to dry the area with a hair dryer. After it appears dry, check to see it there is any corrosion anywhere you see metal. If there is, clean those areas with a q-tip and isoproply alcohol. Then you will want to let the parts air dry. Repeatedly hitting it with the hair dryer can shrink wires inside the system and can cause them not to function. See if that fixes the problem. If not, you may need to prepare your PS2 for a proper burial. And next time you need to clean the fan, use some sort of vacuum to suck the junk out from the back. Hope this helps. Good luck.
Jul 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
353 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
