FixYa.com
Tags:
NEC MultiSync 90GX2  19
Loss of DVI video/black screen
posted by Zinnigan on Mar 12, 2008
When playing Everquest (and so far, only when playing Everquest) my monitor after a while will simply lose the DVI signal and go black. No picture, but the game runs on in the background just fine. Sometimes takes a few hours, and once it happens trying to log back in results in the same problem only within minutes. Any ideas? Also, under the game options it shows the game as reading my old video card (was an Nvidia 7300 as opposed to the 9600 I am running now) and I have no idea how to change that setting to show as correct.
Comment by Zinnigan, posted on Mar 18, 2008
Solved the issue with the wrong video card showing, that's fine now. However, I am still losing my video signal but it seems that it only happens when I'm in 2 different zones, the guild lobby or guild hall. I'm at a loss to explain it. I do have a fan that's running slow (a chassis output fan to be exact) but I can't see how it all might tie together to be honest. I wouldn't think the one slow fan could cause such a specific event to occur.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 13, 2008
Not Rated (0)
Thexder1
Rank:Wiz Wiz
Rating: 83%, 33 votes
The problem is probably related to it showing the wrong video card. I would see if there is any help for everquest on changing that and if you cannot figure it out I would reinstall the game and that should fix your problem, keep in mind that you may have to uninstall in order to reinstall properly.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Monitors
monitor image size
i have a inspirion 531 computer... Answer This...
Monitors
Monitor driver
Dear Sirs! I'm very need the... Answer This...
Monitors
Fuji FP-7688B Power Lite on but...
I think you are right -- but my... Answer This...
Monitors
monitor
I have a 17 inch lcd monitor... Answer This...
NEC MultiSync 90GX2 (Silver, Black) 19" LCD...
Constant lateral screen...
My monitor frequently needs... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
