Question about Dell 5110cn Laser Printer
CD sleeves. can you tell me how to print on CD sleeves using the Dell 5110cn, I think I would use the multipurpose tray... Thanks, Julie
  • jgjg Mar 12, 2008
    Thanks, Julie
  • 778 Answers
I believe that there are kits available that include sheets of CD sleeves and software to help you print to them. Otherwise, if just printing simple labels you could set up the print job to print in the section of the sheet where the sleeve you're printing resides.
If the sleeves are stacked and not like 6 to a 8 1/2" X 11" sheet, then I imagine it would be just like setting your printer up to feed envelopes (if that's possible, in the old days we would but the sleeve in a typewriter and viola. We didn't have a choice on the font though. :(
I hope another one of us posts an easier solution for you, and Good Luck.
Posted on Mar 12, 2008
3100cn won't select paper tray
there is a censor or switch between tray and machine check the censor if not tray was broken where it presses the switch
Nov 07, 2013 | Dell 3110cn 3115cn and 5110cn Color
Dell 5110cn printer Tray Detached error 024-946
Cycle power on the Printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
If tray 1 is being used:
  1. Remove and reseat the tray.
    To remove and reseat the tray, perform the following steps:
    1. Pull the 250-sheet tray out of the printer until it stops.
    2. Hold the tray with both hands, lift the front slightly, and remove it from the printer (Figure 1).
      Figure 1: Removing the Tray
Re-insert the paper tray into the printer and push it until it stops (Figure 2).
Figure 2: Reinstalling the Tray
Run diagnostics on the tray 1 paper size switch on the Dell 5110cn printer
Dec 18, 2012 | Dell 5110cn Laser Printer
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
Aug 19, 2011 | Dell 3010cn Laser Printer
What does it mean by Load MP feeder letter?
That means whatever you are trying to print is set to feed from the MP tray or Multipurpose Tray. The tray that folds out that is used to feed thicker paper or envelopes in. Just check your print setup screen and tell it to feed from the lower tray or tray1. If that is what you were trying to do.
Dec 28, 2009 | Dell M5200n Laser Printer
When you try to print from a networked computer the display goes from saying ready to print to load Tray 1 A4. The tray is full of paper
When you loaded the paper in the tray, did you tell it that the paper was A4 - it may be that on the printer or in the queue definition on the computer that the paper size for that tray is set to something else (eg letter) and the print you are sending is A4 so it is looking for paper but only thinks it has other sizes available.
Nov 13, 2009 | Dell 5110cn Laser Printer
Dell 5110cn Color printing only printing in black and white
check in the printer properties and make sure on the color page that "print in grayscale" is not selected. This option will make the prints all in black (grayscale)....
Dec 31, 2008 | Dell 5110cn Laser Printer
Paper Jam when printing on cardstock 2nd run Dell 5110cn
You were using this prevoiously; I mean previously it was fine. now you have problem.
Because usually this may not be the problem with a printer. This is a problem of paper. You may use duplexing if it allows you.
Mar 24, 2008 | Dell 5110cn Laser Printer
Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Mar 14, 2008 | Dell S2500 Printer
Tried printing on CD Sleeves and the plastic started warping and melting
You can try to lower the temperature of the fuser while printing the sleeves. From the "menu", select "maintenance", then "adjust fuser". The default setting I believe is 0. it can be adjusted from -4 to +2. Lower the setting to -1 and test. If that does not work, try -2, and so on... until the lowest setting at which it does not damage the sleeve. IF you go all the way to -4 and it still warps, then you will not be able to use it for this purpose. Do not forget to set the fuser BACK to the default setting after printing this media.
Mar 12, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
