Question about Garmin StreetPilot C330 GPS Receiver
Battery ? unit turned off while in use in the car. checked car cable , okay. doesnt switch on with usb cable neither. could it be the battery? if yes, how do i change the battery ?
  • pinkig Mar 19, 2008
    how to charge garmin c330 gps from computer
  • Anonymous Mar 26, 2008
    my problem is the same - can't get it to charge
  • 3 Answers
Pins broken on mounting device that attaches to screen.
Posted on Apr 01, 2008
SOURCE:
Volvo ignition problems
first thing check make sure battery 12.6 volts and battery cables clean free from corrossion. if battery cables old as vechicle bad ground cable or positive cable prevent vechicle from starting.if all is good remove check starter and starter solenoid.if both okay problem either faulty ignition switch or the inhibitor switch to keep vechicle from starting in gear.
May 21, 2013 | 1997 Volvo 850
Lights will not work
MAKE SURE BATTERY VOLTAGE IS 12.5 VOLTS.IF BATTERY OKAY.IF BATTERY CABLES VERY OLD YOU COULD HAVE BAD GROUND BATTERY CABLE.IF BATTERY CABLES GOOD.CHECK HEADLIGHT FUSE SHOULD BE 25 AMP FUSE.IF FUSE OKAY.YOU HAVE FAULTY HEADLIGHT SWITCH OR FAULTY DIMMER SWITCH.
Mar 20, 2011 | 1992 Jeep Wrangler
1993 suburban is not starting and it is not the battery. What could it be?
IF BATTERY CABLES OLD THEY WILL CAUSE POOR GROUND HIGH RESISTANCE IN STARTER CIRCUIT CAUSING STARTER NOT TO CRANK ENGINE.CHECK TO SEE IF DASH LIGHTS AND GAUGES WORK WHEN YOU TURN ON IGNITION SWITCH IF NO CHECK IGNITION FUSES.IF FUSES OKAY IGNITION SWITCH IS OPEN NEED REPLACING.NOW IF BATTERY VOLTAGE IS 12.6 VOLTS, BATTERY CABLES GOOD AND IGNITION SWITCH AND FUSE OKAY. STARTER SOLENOID OR STARTER FAULTY.REMOVE STARTER TAKE TO ANY AUTO PARTS STORE THEY WILL TEST STARTER.TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY SO YOU WONT LOCK OUT RADIO.
Nov 02, 2010 | 1993 Chevrolet Suburban
Wont start good battery and starter
IF BATTERY CABLES ARE OLD REPLACE THEM.OLD BATTERY CABLE WILL CAUSE HIGH RESISTANCE IN CRANKING CIRCUIT.CHECK STARTER FUSE.IF DASH LIGHTS DONT LIGHT UP WHEN YOU TURN ON IGNITION SWITCH.CHECK IGNITION FUSE.IF FUSE OKAY.YOUR IGNITION SWITCH COULD BE FAULTY.
Sep 05, 2010 | 1992 Dodge Grand Caravan
One of my usb ports checks okay but fails to work on my dimesion 4700
try replacing the USB cable and if that doesnt work go into the control panel then find the system icon and find device manager. remove all usb controllers by uninstalling them then reboot and see if it works then!
May 11, 2010 | Dell Dimension 4700 PC Desktop
Switching the key on wont turn on anything
FIRST MAKE SURE BATTERY VOLTAGE IS AVAILABLE.BATTERY SHOULD BE 12.5 VOLTS.IF NOT BATTERY DEAD.IF BATTERY VOLTAGE OKAY.BATTERY CABLES CLEAN AND ON TIGHT .CHECK IGNITION SWITCH FUSE IF OKAY.IGNITION SWITCH IS BAD.
Mar 08, 2010 | GMC Safari Cars & Trucks
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
My pioneer DEH-P6000UB doesnt read USB
I have a pioneer dehp-6000ub but there is not cord for the usb at the back,, what cord if any can I use to use a usb drive on it..
Dec 28, 2008 | Pioneer DEH-P6000 CD Player
Garmin StreetPilot C330 GPS Receiver Logo
22 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
