Question about Conair 5200
How to sharpen blades
We have a conair hair clipping set - we use it for our cat who somehow gets his fur all matted up. He is pretty good about some of his grooming but he does have those spots. Anyway, is there a solution to sharpening the blade?
Appreciate any assistance!
SOURCE: Blade won't cut
Try replacing the Drive Lever which is located at the end of the clipper and goes from side to side, simply undo the two screws on the name plate/ gearbox cover and remove then pull the lever out. This is the most likely cause if you experiance the same problem with all blades.
Posted on Apr 25, 2009
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: I have an old Oster adjustable dog trimmer model
YES! YOU NEED TO BUY A NEW BLADE OTHER WISE IT GOIN A PULL THE HAIR
Posted on Jun 27, 2009
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
Do I need to bathe my cat?
Cats are able to bathe themselves, generally speaking, with their tongues and teeth. Nevertheless, there will be times when you will need to bathe your cat - if he/she gets into something really dirty/sticky would be an example of one of these times.
Aug 15, 2012 | Pets - Others
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
My newly bought WAHL hair clipper but it is not sharp enough to cut my hair. what can i do to solve this problem.
The only thing here you can do is, if you want your blades to be sharper you need to send them to a professional sharpening service. Manny's Sharpening can help you with that, We have a mail order service with includes Free return shipping. We only charge $8.00 per blade set.Check out my web page, we also included a shipping Label and order form. Manny's Mail Order Sharpening
Mar 13, 2011 | Wahl Magic Clip Clippers Hair Trimmer
Blades normally glide tight thru hair....cleaned and oiled blades but still meeting resistance on perfectly combed not matted hair. Blades are approx 5 yrs old. Do they need sharpened maybe. Should I...
Ok if you take them appart don't touch the screws you will find it hard to re-align, if your blades haven't been sharpened for 5 years the i think its a very good place to start
Jan 22, 2011 | Andis AGC2 Hair Trimmer
I have conair haircut kit 10 piece and i used it on my brother and it keeps pulling his hair and i turned the power on switch it still pulls his hair whats wrong with the clippers
Sounds like you may need the blade sharpened, it may be dull, otherwise the motor may not be functioning properly. Does he have thick or coarse hair? If so, you may need to go through it lightly in sections otherwise it will for sure pull, I learned that way back in hair school long ago. :) Goodluck!
Apr 02, 2010 | Conair HC90CS Hair Trimmer
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Conair 5200 Logo
138 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
