Question about Canon PC-920 Black and White Copier
How do I find the Total Copy Count on the machine?
Is there a counter, either manual or electronic, for this machine? How to find or access it?
    Sergeant:
  • 331 Answers
NO,
Posted on Jun 12, 2008
SOURCE:
How to find copy counter for mono and colour on Sharp mx2300n
Press and hold the button marked "Copy". Alternatively, press "System Settings", then "Total Count", then "Job Count" and now you have the option to both view and print the readings.
Jan 16, 2014 | Sharp MX-2300N Color Copier
Is there a way to find out the total copy count for the printer?
You can get the copy count for the MF6550 by using the following procedure:
- Press Additional Functions
- Press 2
- Press 8
- Press Additional Functions again.
- Scroll down through the options. There will be an option for Counter -- select it and the copy count will be displayed on the screen.
For page count and configuration page instructions on other copiers, printers, and fax machines, visit the How to Print Configuration Pages website.
Jun 15, 2011 | Canon imageCLASS MF6550 Monochrome Laser...
The printer shows repeatedly the following line: The waste ink absorber is almost full. See manual. Unfortunately I can not find any solution in the CD that came with the machine. Thank you for...
Try this combination menu-scan-copy-scan and go to the service menu,then find something like reset ink absorber or reset purge count.I hope help you.
Apr 07, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My Canon Pixma MP130 tells me my Waste Ink Absorber is nearly full. Manual tells me not to touch but how do I replace or empty?
This is a safety function that Canon ans Epson built into theyr machines. Normaly this problem can be solved by replacing the absorber pads (or cleaning them) however you will need a service mode tool to reset the ink count in the eprom. Search google for the specific tool for your printer.
Good Luck
Dec 09, 2010 | Office Equipment & Supplies
Where is the copy count on the Canon Image runner 5050N?
in control panel you will see a counter botton just press that botton and you will see the total copy count
Dec 06, 2010 | Canon imageRUNNER 5000 Copier
We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
LCD shows waste Ink absorber is almost full - manual says contact supplier
Yes, you need a Canon repair shop to replace the ink absorbers, and reset the absorber count in machine diagnostics.
Jul 19, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Sharp ar-5316
Hi, from memory, the secret test commands are: # I CA #, then 81 to reset main copy count.
Cheers
Andy
Jan 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon PC-920 Black and White Copier Logo
102 people viewed this question
Clive
Clive
old marine
old marine
Ekse
