How to find correct county
A. First, determine the counties you are interested in. Then do one of the following
three steps to get the codes:
1. The National Weather Service Toll-Free Number provides S.A.M.E.
County Codes at: 1-888-NWS-S.A.M.E or (1-888-697-7263)
This is what to expect when you call the NWS number. When you call the NWS
toll-free number, automated instructions will guide you to the S.A.M.E. County
Code(s) you need. The number will be six digits long.
• You will hear, "Welcome to the National Weather Service. You have
reached the Specific Area Message Encoding Program Service."
• If you select "touch-tone" to make your entries, you will be prompted to
enter the name of your state using the telephone keypad.
• Next you will be prompted to enter your county name.
• Then you will hear, "Your geographic code is xxxxxx." (This is your
S.A.M.E. County Code.) Be sure to write it down for future reference.
The system will then give you the option to enter "another combination": This
enables you to get additional S.A.M.E. Codes for surrounding counties.
2. The Internet Web Site of National Weather Servicewww.
nws.noaa.gov/nwr/indexnw.htm.
This is what to expect when you go to the website.
• The link above takes you directly to the list of states.
• Click on (your state).
• Find your county, and record the "S.A.M.E. #" (the S.A.M.E. County
Code) that is listed to the right of your county, and for any other counties
in which you are interested.
WR-100 Owner's Manual
Page 8 www.midlandradio.com
3. Go to the Midland Radio Corporation website at www.midlandradio.com
• Click on the weather radio link at the top of the page.
• At the top of the weather radio page will be the link to the NWS list of
states and corresponding county codes. Click on the link.
• Click on your state and a list of counties and codes will be listed. Locate
your county and then find your code.
To set the country follow the below steps:
A Single S.A.M.E. County Code:
Press "MENU" button to open menu options.
• Press the "UP" arrow to scroll through menu options until "S.A.M.E.
SET" is displayed, then press "SELECT" button.
• Press the "UP" arrow to scroll through: "SINGLE", "MULTIPLE", or
"ANY."
• Display "SINGLE", then press "SELECT." "S.A.M.E.01" will be displayed.
(Note if you are programming a single S.A.M.E. County Code, only the
"01" setting will be used.) Press "SELECT".
• Using the "UP" arrow, find the first digit of your S.A.M.E. County Code.
Press the "RIGHT" arrow to save the digit and automatically
advance to the next digit.
• Program all digits of your S.A.M.E. County Code in the same way.
• Press "SELECT" to store your S.A.M.E. County Code. Press "MENU"
to close the programming menu.
Helpful Tip: The S.A.M.E. code is created using the following method:
• The first digit is the subcounty code-currently 0 in most areas.
• The second two digits represent the state code.
• The last three digits represent the county code.
Multiple S.A.M.E. County Codes:
"ANY."
• Display "MULTIPLE" as explained, then press "SELECT".
"S.A.M.E.01" will be displayed, indicating you will be programming your first
S.A.M.E. County Code at weather radio menu location "01."
• After programming your first S.A.M.E. County Code, press "SELECT" then
the "UP" arrow to advance to "S.A.M.E. 02." Program all of your S.A.M.E.
County Codes in the same way as above.
• When finished entering all your codes, press "MENU" to
Hope that helps.
Regards
Anand
