Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door Opener
Good day
After the severe snow storm on the weekend,my garage door closes to the sensors and then goes back up again.
In the book is says to adjust the force my turning something on the back of the main motor. How much do I turn it and would this be the problem solved?
Thank you
J. Watt
  • 504 Answers
IF YOUR SAFETY EYES ARE MOUNTED TO THE TRACK THEY MAY BE MOVING OUT OF ALIGNMENT AS THE DOOR NEARS THE CLOSED POSITION.
WILL THE DOOR CLOSE NORMALLY IF YOU HOLD DOWN THE WALL BUTTON?
IF THE DOOR CLOSES NORMALLY YOU ARE OVERRIDING THE SAFETY EYES AND WILL FIND THE PROBLEM THERE.
IF IT STILL STOPS THE DOOR MAY BE TOO TIGHT AT THE FLOOR - HOW DOES IT WORK MANUALLY?
IF THE DOOR SEEMS OK MANUALLY THEN CHECK THE SENSITIVITY IT IS ONLY 3/4 TURN FROM MIN. TO MAX. SMALL ADJUSTMENTS 1/8 TURN AT A TIME CLOCKWISE - DO NOT SET THIS ANY FURTHER THAN YOU NEED - IT IS A SAFETY ISSUE.
HOPE THIS HELPS
Posted on Jun 05, 2010
Garage door opener
The green eye receives the the signal from the Amber side. When is not on the sensors won't work. As far as the cold chamberlain did have a few issues with sensors not working or intermediate issues in cold weather. Their solution was to replace the sensors. But before you do that check everywhere the wires are stapled. Make sure that they are not pinching the wires.
Jan 01, 2015 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 4 inches, stops, then goes back down. No flashing lights at all. One sensor light is green, the other is a steady yellow. What's the issue?
something may be obstructing the door, so pull the red emergency release handle and try to pull the door manually.if you cant move it manually, call for professional help
make sure all snow and debris are clear of the area where the door closes
if there are no obstructions, manually set the adjustment controls on the back side of the opener panel. weather can sometimes change the amount of force needed to open/close. adjust the setting with a screwdriver to no more than 260 degrees, about 3/4 of a turn
Feb 09, 2013 | Craftsman Garage Door Opener 1/2 HP Chain...
My garage door will only close to about 80%, and then reverse itself by opening up again. This has never happened before. P.S. This happened during the first major snow storm in our region.
If when the door reverses the main light flashes 10 times you have a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary. If you can't get both lights to come on you have a bad sensor.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener reaches the laser beam and goes back up
Have checked to make shur nothing on the Door is sticking out into the path of the beam. Most door I know of are set so that anythig breaking the beam, while the door is in motion, will send it back up. the beam dosnt stop being looked at till the doors been all the way closed for a second or two.
You might want to look at the part of the door that reaches the laser just before it goes back up, it dosent take much to break the beam, a piece of string could do it.
Hope this Helps
Gem
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changed gear box in craftsman garage door opener
you did not give enough info. If it closes completely and right away goes up, if bulb blinking. if it is, something on door is blocking safety beam. If light is not blinking, DECREASE down travel.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not work
My Garage door goes down half the first time I'm attempting to close it; then closes completely the second try. What's the problem?
Jul 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
111 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
