Question about Eiki LC-XB20 Projector Multimedia Projector
RGB HD15 to Component/RCA cord
I have recently purchased the above mentioned cord to connect my DVD player to my EIKI LC-XB20 projector and when connected I get nothing...what am I doing wrong. Are there settings that need to be adjusted?
I have tried to switch around the component colors and I can then see a picture in black and white...but no sound. I would appreciate any help you could offer.
  • 1 more comment
  • MyElishah Mar 14, 2008
    Unfortunately, this doesn't work. But thanks for trying! I bought new cables and everything... it still isn't coming up.
  • MyElishah Mar 15, 2008
    Unfortunately this is not the problem either. Mute is not on, and I can make the picture really green or really red... but that's it. Still no sound either.
  • MyElishah Mar 16, 2008
    That's what I was afraid of. I guess it just isn't worth it to pay that much for something so small. Thanks!
  • 682 Answers
Test with new cabels -and switch on your dvd first and projector second-confirm that projector input in video status(test with good brand cd).
Posted on Mar 14, 2008
  • Anonymous Mar 15, 2008
    press menu button to display on-screen menu(menu bar). a red frame is a pointer.--move the pointer to sound menu icon---press the volume(+/-) on the remote control to adjust volume- go down to(mute) and confirm it is off.---------.
    press menu and go with the pointer to image adjust menu move the pointer to the colour and press select. adjust the data with left and right buttons. to close this menu.select quit.and then press menu to clear on screen menu.
    if all soft adjustement failed we must go to hardware through qualified service technician.
SOURCE:
I have an eiki lc xg400 at my disposal. I have a toshibi vcr/dvd player. How do I hookup the vcr to the projector and is the hook up different for the dvd? Thank you De
this depends on the signal type coming from your sources
best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
Mar 30, 2011 | Eiki Office Equipment & Supplies
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Laptop won't project onto Eiki
The signal type settings wrong in the menu, or broken interconnection between input board and mainboard of projector, due to shocks during portable use.
Jun 10, 2009 | Eiki LC-XB20 Projector Multimedia...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
Projector powers down and re starts over and over
the colorwheel, the ballast, or the power supply are not working properly.
Apr 16, 2009 | Eiki LC-XB20 Projector Multimedia...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
New projector. which cords do I need?
laptop, vga. dvd, composite or s-video, and audio. gaming console, composite or hdmi, if you have it.
Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
May 12, 2008 | Eiki LC NB2UW Multimedia Projector
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
Breakout cable usage
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Oct 15, 2007 | Panasonic TH-42PWD5UY 42 in. Television
Open Questions:
See all Eiki LC-XB20 Projector Multimedia Projector Questions
Eiki LC-XB20 Projector Multimedia Projector Logo
118 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Ekse
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
