Question about IBM Wheelwriter 30 Typewriter
Typewriter I have a IBM Wheelwriter 3 that is going crazy. The lights at the right side start to flash and the wheel spins and types keys. Please help,
  • branestorm Mar 17, 2008
    OK, so I left it unplugged over the weekend. Just plugged it in a few minutes ago. I am not real good with a soldering iron. Suppose things dont work out - where do I go from there. Is this something I should have replaced or am I better off purchasing a new typewriter ?
    Thanks for all your help, it is greatly appreciated.
  • 398 Answers
Oh, bad news. Indicates a confused main board. Only thing I can suggest is to unplug it from the power and let it sit over night, plug it pack in and try it again. Is it is still confused it needs to go into a repair center.
Posted on Mar 14, 2008
  • Ron Dufek
    Ron Dufek Mar 15, 2008
    Did it work after unplugging it over night? Hope so!
    If the problem pops up again, I would suspect that a capacitor on the main board might be going bad. The chances are that if there is a bad capacitor (or two) the problem will return and each time the “fix” will last less time.
    If you are not real good with a soldering iron I wouldn’t attempt this if I were you. Pull off the cover. Many times you can see signs when capacitors go bad, “they bulge or leak”. If you don’t know what a capacitor looks like maybe you should reconsider your skills with a soldering iron.
Ibm wheelwriter 3
there should be a "switch" on the right side of your keypad to move to the ink position
Aug 13, 2014 | Office Equipment & Supplies
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
Model 6784 -wheel won't spin
The wheel is probably moving but the print solenoid cap is probably broken. We sell them with installation instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Jun 02, 2010 | IBM Wheelwriter 6 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Nov 13, 2009 | Lexmark Wheelwriter 10 Series II...
My ibm wheelwriter 15 series II TYPEWRITER HAS FLASHING LINE SPACING LIGHTS 1, 2 &3 WHAT SHOULD I DO TO REMEDY THIS CONDITION
Rattling the brain cells...., I think tyhis used to happen when the print wheel was bend and couldn't roate freely, check the daisywheel hasn't any bent arms and that ribbon or corection tape are not stopping it from spinning, ensure it is locked in place, try another whell if you have to ensure.
Nov 06, 2009 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 6
1press and hold the code key and type the # 1 thru 99 wher you want to store the job(chose any one number)
2 the store light should blink
3 the ARtn light comes on
4 the carrier returnes to the left margin
4 the printwheel spins
5you may begin typing when the store light is on solid
6 let the carrier return automatically at the end of each line of type
7close the store when finished by pressing and releasing the store key
Mar 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
