Please help us
Everytime our washing machine is spinning the OE is blinking and not working the dryer... what is OE means.... please help this problem.. tnx so much
  • robert samples May 11, 2010
    love to help but first you need to post the brand and model number off the serial plate thats on the unit it will get you a lot more answers
    President:
  • 1,314 Answers
It means that you not draining properly if it has a lower panel remove it and find the drain pump you will need to check the filter in the pump ig you have a shop vac pull the water out through the drain hose before opening the pump as there will be water still in the tub i don't know what kind of washer you have so i cant be more specific
Posted on Mar 12, 2008
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
LG WD 1457RD washer dryer will no spin stops on 14 with OE alarm have cleaned filter etc still not working
pull out plug
check the pipe from the drum to the pump it may be blocked??
or your pump needs to be looked at
Dec 14, 2013 | Washing Machines
Dryer does not spin dry, water left in drum...Error code OE
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 02, 2011 | LG Dryers
Help!! the washing machine wont spin out it keeps commin up wiv oe?? plz help
OE means that the drain filter or hose is blocked or kinked or clogged.
Clean and straighten the hose and clean filter.
Good luck
Feb 08, 2010 | LG WD-16115FD Front Load Washer
What does oe mean
Hi
all washing machines irrispective front load or top load washes ,rinses and spins. Then you need to take out the clothes and put it in a seperate dryer.
In all in one the clothes are washed rinsed spin then dried too. Hence saving you the effort and also space for having an additional driyer.
Its the in thing now...
Regards
Berry.
Feb 01, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
From kim , we have a wm12311fd i put a wash in a
CHECK WATER PUMP FILTER IF OK CHANGE PUMP.... hope this works..01179512835
Dec 30, 2009 | LG Washing Machines
LG TROMM - Won't spin - Spin button - blinking
Aug 10, 2009 | LG WM2277H Stainless Steel Front Load...
My LG 2277HW gave the LE error and we replaced the entire motor based on a Washing Machine Repair Company's advice. Within the month the machine would not spin the clothes all the way out and eventually...
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
The LE issue should of been for the followinig, not a motor:
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The ball sensor is out of order/defective.
The OE error means it is not draining. Two diffrent issues.
Are you sure you cleaned out the drain filter on the bottom? Not just drained it. You have to drain it then pull the filter out and clean it.
Mar 01, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
