Not sure but maybe this article will help
http://epsonstylusphotopx700w.blogspot.com/2009/11/epson-waste-ink-counter-reset.html
Stella Here
NIce post ......VEry useful information but one can also find more details about ink pad resseter software.
SOURCE: reset code for epson px700w ink pads showing full
Hi
You can purchase a service manual and the service program for your printer from. http://www.2manuals.com/index.php?cPath=56
the computer program is used to reset the waste ink counter, follow instructions in the service manual to first replace the was ink pads, only then reset the waste ink counter with the service software for your model.
It would be recommended to take this to a epson service center, but you may do this at home if you wish.
Thanks and good luck,
Ekse
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
SOURCE: ink pads on epson px700w
Remvoe the ink cartridges after using the maintenance keys to bring in the ink cartirdges to the middle to be removed. replace and take a test print. If errors are present then try a resetting.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
SOURCE: reset waste ink counter Epson PX700W
There is a guy on ebay user ID: sophina111 - he is selling them for £4.99 on eBay - thats how I fixed mine. Search for: Epson Printer Waste Ink Pad Error Counter Reset Fix
Hope this helps you - as it took me ages to find.
