Laptop intermitent boot
Hi i have a dell 5000e laptop and sometimes it will boot and other times it will not,i have tried different ram and different hdd.
also when it boots and goes into win xp after about 5 mins it freezes
  • boldi Mar 12, 2008
    HI Mike,
    Thanks for reply i will try then let you know.
    boldi
    Genius:
  • 1,019 Answers
sounds as if the processor is faulty or overheating. remove the cpu. and re-seat with thermal compound. would recommend arctic silver.
Mike @ Compurepair.
Posted on Mar 12, 2008
  • Mike Waldron Mar 12, 2008
    No problem buddy.
    Any problems, let me know.
    I,m here to Help.
    Regards mike @ compurepair.
Dell 1745 studio laptop beep code 434
This is either a RAM issue or the betteri on the motherboard which is dead.
Try to replace the RAM first (not the cheapest but the easiest to do), if you still have the same issue replace the time battery on the motherboard
Here are 2 links to help you:
Manuel Dell 1745
Dell beep codes meanings
Jan 03, 2013 | Computers & Internet
Inspiron 5000e adapter where does it go
If you mean the power adapter plug, that connection is on the right side of the laptop near the back of the machine. It's between the PC Card slot and an air intake. For pictures of other connections/ports on the Dell Inspiron 5000e, see http://support.dell.com/support/edocs/systems/pblan/overview.htm and scroll down.
I hope this helps.
Oct 10, 2011 | Dell Computers & Internet
Access to motherboard of an old Dell Inspiron 5000 to remove unknown bios password. Thanks
To reset the BIOS read the information from this link.
In case of a laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 28, 2010 | Dell INSPIRON 5000E (969PG) Motherboard
How do I fix my Dell Latitude D610? The problem is: whenever I turn on my laptop, only the scroll lock light blinks 10 times and the screen stays blank. Any solutions?
HI There,
The ten blinks is the Dell Error Code for RAM problems. Your laptop's RAM is easily accessible. Usually, your laptop will have 2 sticks of RAM in 2 slots just under a small black cover with 2 screws on the bottom of the laptop. Sometimes, 1 stick will go bad and cause the laptop to be unable to boot up. By taking out both sticks and only putting one back each time, you can often find the culprit. One stick will run the laptop just fine and one won't let it start at all. It's also possible that both have gone bad and you may end up having to buy at least one new one (stick of RAM) to make sure.
In these circumstances, most laptop repair guys (like me) would also take out and reseat the hard drive, wireless card, dvd/cd player as well.
If you haven't done this sort of thing before, find a friend who has or study the your laptop's Service Manual at the Dell Support site and decide whether you're ok with trying yourself. Don't go purely by the manual alone. Google every procedure you're going to try and find forums where others explain little tricks to look out for.
Be Well
Aug 09, 2010 | Computers & Internet
My dell inspiron will not boot it says no bootable device found
Hi, try pressing the ESC key during bootup, this will allow you to boot in safe mode, from where you can reset your operating system to a time before the problem started.
If this dosn't help come back to me for help on re installing operating system.
Aug 01, 2010 | Dell Inspiron 1525 Laptop
Dell D600 won't boot
I am sure Not the CPU or fan problem. Follow the below step to repair it.
1. Just press the power button 5 seconds or more to see the laptop can reboot or not. 2. replug the memory modules. 3. maybe the power supply device failed that the electronic volt is not enough to boot the laptop. Just replace a new Dell latitude d600 battery power supply.
Jul 28, 2010 | Dell Latitude D600 Notebook
Will windows 7 run on dell5000e
I wouldn't. In theory, it could install it with enough HDD space, but in practice it would not be productive, would no doubt take more than 5mins just to boot up, and God knows how long to open any program.
Id upgrade to something from at least 2004/2005 then install windows 7 on that, something with at least 2gb of RAM.
Hope this helps in some way
Jan 02, 2010 | Dell INSPIRON 5000E (969PG) Motherboard
Freezing up
Press f8 when starting up and see whether the problem still occurs, f8 = safe mode.
Mar 26, 2009 | Dell INSPIRON 5000E (969PG) Motherboard
Dell 5100 laptop memory upgrade
try removing it again power on then off. again put yr ram it should boot. less u want to may be remove the processor then put it back as well at times they could stop system from booting
May 23, 2008 | Dell Inspiron 5100 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
