Question about Samsung SCX-4216F All-In-One Laser Printer
Line in middle of paper
Hi there, I have a similar problem with this fax machine but it prints a line in the middle when I send only? Should I do the same thing you suggested for the other person?
Thanks,
pw
  • 161 Answers
Cannot recall what I told the other person, but your problem is dirt or some sort of spot in the small rectangle glass at the left side of the big scanning glass.
Posted on May 29, 2008
SOURCE:
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
When receiving a fax there is a black line down the middle of the paper
If you can copy or print and there is no line, the line is coming from the fax machine of the sender.
Dec 24, 2009 | HP Officejet 6500 Wireless All-in-One...
I get a line down the middle of sent and received faxes
If the machine is sending images with a line down the middle, then the scann glass is dirty, open the document feeder on the fax machine, you should be able to see the scanner glass, Clean this with a glass cleaner and a soft cloth, Take not of where the line usually is and be sure to pay special attention to this area of the glass, as it may have some error correstion fluid or other debis on the glass. Try making a copy, is should be gone.
Apr 15, 2009 | HP 1040 Plain Paper Inkjet Fax
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Screen says Printing Online
Make sure the phone cord is plugged into the LINE port of the fax machine.
Check the phone line with a regular phone.
Nov 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Trouble shooting
Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
Nov 12, 2007 | Office Equipment & Supplies
Samsung SCX-4216F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
