Question about Aprilaire 700 Humidifier
Loud "Glonk" when humidifier turns off
Since its installation in December, my humidifier makes a loud "Glonk" when the furnace turns off. The noise is coming from the solenoid switch which does not sound as loud when standing next to the unit, but it seems to reverberate throughout the house. My contractor, who had been around a long time, went out of business shortly after the install with a new Trane furnace. I have a different contractor who installs Aprilaire products and who has been fixing lots of issues with the unit since its install, i.e. replaced fan motor, humidistat, and, in an attempt to stop the noise, a new solenoid. Now I'm being told that this noise is typical and I "need to get used to it".
Any ideas?
  • PKslice Jan 20, 2009
    Yeah I have the same problem - clunk when the solenoid opens for the water to flow through the humdifier. Wuold not have bought one of these had I known. At least the old drum-foam unit was quiet. I have tried everything to get it to be quiet but no luck.
  • Anonymous Mar 24, 2014
    After the humidifier has been running, it starts to make a loud, continuous noise. Sometime it stops, but sometimes I have to hit it to make it stop
  • 30 Answers
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Posted on Mar 13, 2008
I had the same problem. Racingsmoke is correct. I too turned down the water pressure at the saddle valve & the clunking noise went away.
jweigt
Posted on Jan 25, 2010
  • ralph mouth
    ralph mouth Dec 12, 2013
    I measured voltade at solenoid and it was 24Vdc, yes dc....??? This in itself would cause a problem.
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Bad Problem with solenoid valve.
If the valve noise is excessive, or more than it was originally, then yes, replace the valve.
If the noise is no worse than it was originally, then you may be overly sensitive to the noise its making.
Also, check that the valve has not shifted slightly in such a way that it's opening and closing rattles it against something that it didn't used to rattle against. A sheet metal panel will amplify the valve opening and closing.
Let me know what you find.
Dec 12, 2009 | Honeywell Power Humidifier: Furnace...
I have a Honeywell HE225A humidifier installed on my Trane furnace. Due to water noise the solenoid on the unit was disabled and a new solenoid was mounted in the rafters to eliminate the noise. This...
This posted question is exactly one year old, but I just got this solenoid valve assy from ontimemall in Phoenix AZ. I don't have the receipt right here, but it was about $90. It is classified as: honeywell 32001639-002 solenoid valve.
Dec 08, 2009 | Honeywell Humidifiers
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
The fan or blowwer on my furnace is to loud. how do i fix this?
Hi!!! your fan blower has a capacitor right next to it change that first and test it.If sound is still there then your fan blower windings are getting bad..Good luck..but first change run capacitor .
Jan 05, 2009 | Honeywell Power Humidifier: Furnace...
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Aprilaire 700 Humidifier Logo
1,721 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
1STHVACMAN
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
