I mistakenly uninstalled/deleted my videocard and now i can't get my monitor to come on like it should
  • ELITTL8120 Mar 12, 2008
    windows vista
  • Sankar N May 11, 2010
    what version of operating system installed in ur computer ?
  • 26 Answers
Switch on your computer while booting press F8. select safemode. in safe mode. u can run system restore when windows prompt. restore to earlier date. this wil solve your problem.
Posted on Mar 12, 2008
Computer no turn on
CHECK WITH A OTHER MONITOR.
CHECK THE CABEL SHOULD SIT TIGHT IN BOTH MONITOR
AND VIDEOCARD.
THE VIDEOCARD SHALL SIT TIGHT SCREWED,AND WELL
SEATED TO THE MOTHERBOARD.
THE VIDEOCARD CAN BE BROOKEN.
Feb 27, 2014 | VIA EPIA VB7001G Motherboard
Parts
do you mean no picture ? .either the monitor is brooken.
or your videocard.
all cabels should be seated tight.try with a other monitor and you get the answer if it's the monitor or the videocard.does a other work yours is brooken.
Jun 29, 2013 | ASUS MK241H Monitor
Power problem
DO YOU MEAN NO PICTURE .?
1.CAN BE BROOKEN MONITOR.
2.OR A BROOKEN VIDEOCARD.
3.CHECK WITH A OTHER MONITOR IF IT'S WORK THE MONITOR IS BROOKEN,IF NOT PROBERLY A BROOKEN VIDEOCARD
Jun 28, 2013 | Computers & Internet
Everything works except the monitor. The monitor cuts on but says no signal
if changed videocard and monitor shows no signal,the videocard don't get enough power.
diffrent videocard can need moore or less power.
Apr 22, 2013 | iBuyPower Computers & Internet
Dra.comI was running out of space, uninstalled several programs taking care of not deleting any shared libraries, also I installed the latest windows updates and now my monitor is not recognizing the best...
Use what works and stop updating unless you absolutely have to. That procedure most of the time creates more issues than you can imagine and often renders a machine useless! If not broken, leave it alone!!!!!!!!!!!!!!!!!!!!
Aug 28, 2017 | ViewSonic VA1703wb Monitor
Going to sleep
Problem not in your monitor, but in your videocard, I've got the same. Your videocard overheats and your monitor shut down. You need to check cooler on your videocard. Maybe it full of dust. Sorry for my bad english) hope it helps to someone.
Jul 04, 2010 | Samsung 760BF (White) 17 inch LCD Monitor
Monitor problem philips 170c 17" powers up shows pic for short time screen go's blank green light stays on can any 1 help thanks
it may be a problem with the playback of your monitor or just the pins at the back of the tube of your monitor. but first check your videocard. check the connections or uninstall the card, clean the contact points of your videocard and install it again.
Mar 14, 2008 | Computers & Internet
My monitor is not allowing me to display a resolution
If you have the origional CD that came with the monitor, use that to re-install the drivers for the monitor back onto the pc. Then go to viewsonic and look for updates. Do a "system restore" and put the system back to the condition prior to doing all of this. I will re store your files to what they were but "system restore" will not roll back "windows updates". This will tell you if it is something you did or windows did.
Aug 16, 2007 | ViewSonic VA1703wb Monitor
Screen goes black with white horizontal line.
WHEN does this problem occur? Does it ONLY happen after the computer loads Windows (or another OS), or does it happen as soon as you turn the monitor on? We really need more information before we can provide specific advice or suggestions... IF this happens as soon as you turn the monitor on, switch it with a different monitor. If the problem goes away, the original monitor is defective, and probably not worth the cost of repairing it. If the problem ONLY happens after you load Windows, boot the system into Safe Mode (press the F8 key during bootup until you see the menu which allows you to select Safe Mode), then reboot and see if the problem has been resolved; simply booting into Safe Mode, then rebooting the system into Windows MIGHT solve this WITHOUT requiring you to change any system settings... IF the problem remains in Windows AFTER you've booted into Safe Mode AND rebooted back to Windows, the videocard driver might be corrupted. In that case, you'll have to reinstall the vidcard driver to correct this problem... If all else fails, it IS possible that the videocard itself is defective; if installing an updated driver doesn't work, try swapping the videocard with a different one. BE SURE to uninstall the OLD videodriver, and install the proper one for the new videocard; if you don't install the correct driver, you could create MORE problems than you have right now...
Mar 30, 2007 | Mitsubishi DP930-BK (Black) 19 in.CRT...
Blank screen
It could be, either your monitor have gone bad. The videocard is faulty. Or worst scenario: the motherboards graphic port (AGP?, PCI E port?) have kicked the bucket. If you have the possibility? Try the monitor on another PC. The same goes for the videocard. If you have'nt got a friend, that is willing to let you test the monitor / videocard? Take them to a service station. I guess, they wont charge you that much for testing the stuff. Ps. also try to connect your monitor to the other connector on the videocard, using the "DVI adapter", that probably came with your videocard bundle. If you did'nt get any DVI adapter? They just cost a couple of bucks in a PC hardware store. goranpaa
Apr 16, 2006 | Dell E773C 17" CRT Monitor
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
