Question about IBM ThinkPad T42 Notebook
Pin assignment for LCD interface cable
Would you be able to provide me w/ the pin assignment for the LCD Interface cable (part # 91P6804)?
Thanks
Vance
vancedennis@comcast.net
    Problem Solver:
  • 28 Answers
You will get a better response if you pay for the expertise we have to offer!
Posted on Jun 24, 2008
Machine well not turn on it has f 70
NOTE: I do not recommend checking voltages unless you have experience and feel safe and confident in doing so, otherwise I recommend calling a service technician to diagnose and repair your washer.
QUICK TEST
  1. Lock the control by pressing and holding the cycle signal button.
  2. Press the Power button.
  3. If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
NOTE: This is a quick test you can try to get to a quick resolution, but remember if the Lock Light does not blink once the power button is pressed you will need to follow the standard checks below.
  1. First try to put the washer into the Diagnostic Test Mode per the Tech Sheet by pressing any key except Stop/Cancel and the Control Lock for 2-5 seconds on and 2-5 seconds off 5 times as outlined on the tech sheet; at this point the Right Hand Interface should light up.
  2. IF the Right Hand Interface did not light up in Step 1 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). If you do not have the 5 VDC then replace the Machine Control Board.
  3. IF the Right Hand Interface did light up then remove the J003 connector. This is the 9 pin connector that goes between the Right Hand Interface and Center Interface.
  4. Short across (Pin 7 to Pin 8) on the Right Hand Interface.
  5. IF the Right Hand Interface did light up then replace the Center Interface due to a failed "Power" key.
  6. IF the Right Hand Interface did not light up then check from (Pin 1 to Pin 7) and (Pin 1 to Pin 8) on the right hand interface at the J003 connector you should have between 1.2vdc to 1.5vdc.
  7. Also check for DC voltage on the J004 (10 Pin connector) on the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 10. You should have between 1.5vdc to 5.5vdc.
  8. IF you do not have the DC voltage at either of the checks above replace the Right Hand Interface.
NOTE 1: The #1 Pin on both the J003 and the J004 is identified by the white wire. NOTE 2: The picture below is the J004 connector that goes from the Center Interface to the Right Hand Interface and the red arrows are pointing to the check points for the 4 to 5 VDC and the J003 connector.
Image 1 Image 2
Post back your findings and your model number.
Nov 02, 2012 | Kenmore Elite HE5t Washer
I've lost the installation disc and want to transfer mini dv films from my canon mv930 to my computer
According to page 80 of the user manual for this camera (click here for manual), the installation disk will not help you with transferring movies from your camera to your computer.
The instructions state that you will need a computer with a 4 or 6 pin DV (firewire) interface adapter, a 4 to 4 pin or 4 to 6 pin DV interface cable, and the movie software that came with your computer. According to the user manual, drivers for this DV interface are built-in to Windows 98 and later versions of Windows.
Assuming you have a Windows computer, I would suggest using Windows Movie Maker to import and edit your movies from your camera. If you have a Mac, then iMovie will be able to handle this very nicely.
The 4 to 4 DV interface cable is available here: (click here)
The 4 to 6 DV interface cable is available here: (click here)
Your computer will have to have a 4 or 6 pin firewire adapter either built-in to it or provided by an add-on card of some sort.
If you provide the make, model number, and operating system of your computer, I may be able to suggest some sources for the firewire adapter if available.
Thanks for using FixYa. If this solution was helpful, please choose either 3 or 4 thumbs-up to show that it helped you.
Mar 05, 2011 | Canon MV930 Mini DV Digital Camcorder
How to assign IP address through command prompt. Kindly share the screen shot as well ?
STEPS TO ASSIGN STATIC IP ON ANY INTERFACE THROUGH COMMAND PROMPTExample IP's ,Subnet, gateway
1. Click on start
2. Click on Run and type cmd. Press OK.
Now the command prompt will be opened.
3. Type the command
netsh interface ip set address name="Local Area Connection" static 192.168.1.5 255.255.255.0 192.168.1.1
Where Local Area Connection is the interface name.
The static IP address we assigned to the interface is 192.168.1.5.
The subnet mask is 255.255.255.0
The default gateway address is 192.168.1.1
Feb 09, 2011 | Microsoft Windows Server Standard 2003 for...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Could not open youtube videos. Message shows .aui
AUI (attachment unit interface) is the 15-PIN
physical connector interface between a computer's network interface card (NIC)
and an Ethernet
cable. On 10BASE-5
("thicknet") Ethernet, a short cable is used to connect the AUI on the computer
with a transceiver on the main cable. In 10BASE-2
or "thinnet" Ethernet networks, the NIC connects directly to the Ethernet
coaxial cable at the back of the computer.
IEEE Hope that helps, Thanks, Sea Breeze
http://www.appliance911seabreeze.com
802.3,
the Ethernet standard, defines the AUI 15-pin physical layer interface. This
interface is also called a DB-15 interface or a DIX interface (DIX refers to the
three major companies who helped standardize Ethernet: Digital Equipment
Corporation, Intel, and Xerox
Oct 03, 2010 | YouTube Videos
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Router unable to acquire ip address
You're not telling us much. What's the OS and what have you tried? Wired or wireless? This problem is usually solved by resetting the router to defaults and starting over, following the directions carefully.
Oct 07, 2007 | D-Link (DI-784) Wireless Router
IBM ThinkPad T42 Notebook Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
