Dead set I have my set in the shop. They have already replaced the Y board and the set is still dead. Should I go ahead and have the power supply board replaced? Or is a a lost cause?
  • Corynne Mar 13, 2008
    The original problem was the set was dead.
  • jcmobile Apr 13, 2008
    I have the same problem, although I have not had any work done on this set it is completely dead. Fuse was good in the power supply board. It worked great and one day just shut off. Where is a good place to find a replacement power board.
    Problem Solver:
  • 16 Answers
What was the orignal problem you had?
Posted on Mar 12, 2008
  • Anonymous Mar 15, 2008
    The power board is mostly likely dead due to the fuse but you may not get that type of fuse to purchase any where I tried. it will be easier to replace the board with a good use one, where are you located? contact me at [email protected]
    Below is the answer to fixing my tv, In the pic the caps are the blue ones
    next to the yellow coils.
    Earlier I told you the fuse might be the problem, but first change these three caps as they are usually the problem for no power on these boards. You a]can get the caps from a site called digi-key.com their phone
    # is 1800-344-4539. The part #s are EF6225-ND you need 1of these and
    E6105-ND you need 2 of these, the cost is $16 for all. Let me know how
    it went.
SOURCE:
Dead display
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 16, 2016 | Televison & Video
My samsung plasma tv has no power, it is a 43"
Sometimes it can be your power outlet in your wall try to plug something else into the same outlet that the tv was plugged into if you have not already
Oct 09, 2012 | Televison & Video
60 inch LG Plasma, did have to push the power button 5 to 7 times to get the TV to power up. Now it will not come on at all
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 60PC1D 60 in. Plasma Television
Just ordered a replacement Sanyo DP 46848 power supply board from eBay. What I want to know is that it's safe for me to remove the old board and replace it with the new one. I have already removed...
If you have done this kind of repair before and have the proper
tools, then go ahead and do it.
If not, get someone who is familiar with power supply boards,
their removal and installation, and who has the proper tools,
and work with him/her on this project. Next time you then can
do your own repair.
Aug 29, 2011 | Sanyo DS13204 TV
My TV will not power on but I here when it is plugged in that it has power it will click like it is wanting to power up but nothing happens. I had an electrical storm prior to my problem
The tv power supply board it is dead,u said had an electrical storm in ur area before this problems happen.Yes.Than the tv have a power surge by of the electrical storm already,the storm had a charge sent of an electrical magnatic statics to ur tv and now kills all those sensitive ICS on ur tv power suppply board already.The tv power supply board already dead that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 08, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
I have a 32" Protron
The tv power supply board,that the board where the tv power a/c cord plug into it.U know basic electronic,have all the tools also can do soldering work too?Tries check the tv power supply board for dead components parts call capacitors parts,most of the times the capacitors parts are bulges ups or puffing ups onto it tops.These capacitors parts are dying or already dead.These capacitors parts are dead must to be replace.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 22, 2011 | Protron PLTV-32 Television
Set is about 2 years old. Powered up and heard a loud snap/pop noise and unit went out. Will not come on Can you help?
U have a soldering iron,desoldering pump or desoldering braids,solders.U understand basic electronic and can u do basic soldering?Yes,take the tv aparts,take out the power supply board,that the board,where the power a/c cord plug into it.That the power supply board,most of the times those parts call capacitors are dead,these capacitors are alway bulges up on it tops or puffing up on it tops.These capacitors are dead,must be replaced.These capacitors are dying or already dead capacitors,that why they are bulging up on it tops or puffing up on it tops,after u replaced these capacitors ur tv will power up again and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
The blue power light just binks when it's plugged in, the power button doesn't even have to be pressed. is that the power supply or the logic board? (already ruled out inverter board)
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
Jul 15, 2010 | Sceptre Komodo X37SV 37 in. LCD Television
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
Hi shawnn,i'd like to know the if it's only power supply faulty and i need the board #?thanks man.
have the same problem and already replace ps from fleabay and still dead , looks llike the problems is on the main board.
Apr 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Ekse
