Question about Canon i860 InkJet Photo Printer
Canon i860 I have a Canon i860 printer. It was printing fine, then today the colour was all off, then when I tried the deep cleaning it just got worse. I then tried to do the head alignment, and from there it went down hill. The paper is now stuck in the printer and I have a Service error code or 5200. I can not seem to find out what that means or can I fix it. I need help!!!??? I switched from Photoshop Elements 3.0 to 6.0. The printer soon thereafter greatly reduced the intensity of blue-green color. The nozzle check yielded a brown color instead of black in the M and N rectangles but the alignment seems fine. I cleaned, then deep cleaned the inks and the ink levels are visible in all the tanks. I have spent at least 5 hours on this problem and would appreciate any help.
  • Anonymous May 20, 2008
    unable to clean printer
  • jfuschetti May 21, 2008
    My printer was was doing well printing black. Then it suddenly changed to brown color print Why?
Have a look at the yellow cartridge. I have had trouble with inks leaking into each other...most noticeable in the yellow. I have no solution...perhaps the printhead is a piece of ****...works well when it works.
Posted on May 20, 2008
SOURCE:
My canon i860 will not print out black text of any thing and also some images.
try going to maintenance and do deep cleaning if this does not work just pm me and we can go virtual and ill do it myself for you
Apr 15, 2011 | Canon i860 InkJet Photo Printer
Cyan not printing on my Canon i860 printer. Put in new Canon cartridge. Did deep cleaning 5 times and took the cartridge out and cleaned with a swab and alcohol. No change.
There's usually a sticker over the bottom holes and maybe one over the electronics (?) make sure these are off.
Possible bad cartridge.
Dec 01, 2009 | Canon i860 InkJet Photo Printer
Nozzle for cyan blue will not cleen. photos print without blue.
Try print head cleaning first. if standard cleaning does not work perform deep cleaning. If the problem still persist you should replace your print head.
Source:
Canon i865 Service Manual
Inkjet Zone
Nov 03, 2009 | Canon i860 InkJet Photo Printer
After deep cleaning the print heads, it will only print one page
This sounds like the print head alignment is not stabilized and may indicate you need a new print head ($$$). Try looking in the Service Manual.
A copy of the Canon i860 Service Manual is downloadable at:
http://rapidshare.com/files/179582794/Canon_i860__i865_SM_-_printer1.blogspot.com.rar
The password to open the compressed PDF file is: printer1.blogspot.com
Jan 24, 2009 | Canon i860 InkJet Photo Printer
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
Canon i860
Print head temperature rise [5200]
I would assume that the cleaning efforts resulted in oveheating the print heads.
Please ensure that you have sufficient ink, as ink acts as a lubricant for the heads.If you try to use them while empty it is equivalent to driving a car without oil.
Take your time..
Verify ink is in all cartridges.
Remove paper jam
let the printer cool off (heads)
Chances are the head alignment is not necessary and you are low on one of the inks...
Try this test program (Page) to isolate low colors...
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Feb 10, 2008 | Canon i860 InkJet Photo Printer
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
My canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
287 people viewed this question
Clive
Clive
old marine
old marine
Ekse
