Question about Samsung DVDR120 DVD Recorder
Recording After initializing the disc, I record a DVD from a DVR and when finished I finalize the disc. I can view it on playback using the DVDR120 but cannot view it on anything else. WHY?
The device defaults to initializing discs to DVD-VR format. I believe this is incompatible for all devices except other DVD recorders. You need to reinitialize the disc to DVD-R format from the menu. These should then work in other players.
Posted on Mar 27, 2008
SOURCE:
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
DVR
yes but it will depend on memory of the cd in order for it to be a succesfull burn
Aug 10, 2008 | Philips DSR704
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Viewing pictutes
Please finalize mini dvd disc if its full or when recording is finished.
Without finalization dvd will not be playback anywhere except camera.
DVD Finalize option is available in camcorder Menu.
May 11, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Samsung DVD-R120, can I save what?s on a DVD-R that won?t play?
If it will not play either on the recorder it was recorded on or any other player, you need professional help retrieving the data. There are places where this can be done, but it will probably cost MANY times what the disc does.
Jan 21, 2009 | Samsung DVDR120 DVD Recorder
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
DVR recording
open the unit and check the connexion of the burner
Jan 21, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Recording to DVD on samsung recorder from dish network dvr
Connect the "yellow, white , red) jacks from the Satellite to the same colored inputs on the DVD. If you use "Input 1", for instance, set the dvd to record on Input 1. Set Satellite to desired channel. Good to go.
Sep 08, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
101 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
