Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Lines on TV with DVR-625
Since installing our DISH Network DVR, we have a line that runs across our TV. When I mess with the wires, the line moves, and sometimes goes away, even for days. We've had Dish Network for going on 12 years now and have never had this problem. Any suggestions?
Try using a better cable from the receiver to the tv. sometimes less expensive cables dont "ground " as well as they should after a few years. the more shielding the better. the cable here will sell you the cable much cheaper then going to any store and its better quality, even if your not a customer of cable.
hope this helps
Posted on Mar 27, 2008
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
Duo DVD 625 to HDMI
Hi my name is Mike Houston a Social Media Representative at DISH. With our Duo SD 625 DVR, it cannot receive HD signal, there will need to be an upgrade to our HD duo DVR systems. If you have any further questions about our DISH equipment please e-mail me at; michael.houston@dish.com
May 29, 2012 | DISH Network DVR-625 DTV Receiver /...
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch...
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Jul 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I get closed captioning on my 625 dish dvr.
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I migrate my recorded programs from the DVR-625 to my XP pro PC?
It is not possible due to incompatibility, All dish VIp seris recrvs can utilize an external hard drive but is still different format styles from a pc. it will erase all your porgrams whenh you move it from device to device. at this time the USB ports are disable on the 625 DVR.
Oct 11, 2009 | DISH Network DVR-625 DTV Receiver /...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
On screen caller id failure
common problem on 625 receiver. Have you hit menu 6-1-2 to enable caller id? If so call Dish and have them send you a new receiver out and give it a try. I'm sure it won't work every time, but it has to be better than what you have.
Apr 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Installing a DVR
You are not able to use the DVR unless you have Dish Network services. Cable operates at a different frequency than Dish Networks Dish Pro Plus Receivers.
Sep 07, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
110 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
