Question about Sony Ericsson W200i Cellular Phone
Phone turns itself off
Battery fully charged, but if I dont use phone for half an hour or less it turns itself off.
    Problem Solver:
  • 6 Answers
The first thing to try is a hard reboot - this means taking the sim out for 20 mins and leaving it off. Put back together and test it to see what happens.If this doesn't work i would try your sim in another phone and another sim in your phone as you may have a lose sim connector. If your phone still turns off you know you've got handset fault. If the other phone turns off you know you've got a sim fault - if the later speak to you service operator.
If handset fault i would frist recommend (if possible) trying another battery as the charge indicator will not always relate to the battery correctly. If avaliable try looking for a software update from the Ericsson website - this may solve it. If still no luck then i would suggest a factory reset (THIS MAY LOSE SAVED DATA SO BACK UP IMPORTANT THINGS FIRST) if this doesn't work then it would suggest to me it's beyond repair and if under warrenty try getting it replaced.
Hope this helps.
Posted on Mar 15, 2008
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
How long should i charge a new optimus black
The optimus black phone should take 2-3 hours to fully charge. When you get a new phone, however, it is generally a good idea to let the battery completely die before you start charging it.
Over time, batteries hold less and less charge. Supposedly, by allowing the battery to completely die before charging it the first time, you improve the longevity of the battery.
Feb 10, 2013 | LG P970 Optimus Titanium Black Android 2.2...
IF I WILL CHARGE MY PHONE IN A FEW MINUTES IT SHOWS FULLY CHARGE
I'm not certain what your question is you made a statement more or less.
I do know that alot of cell phones will show that they are fully charged after minutes of charging, but then very quickly go back down to almost dead within an hour. This is because the phone is not actually fully charged. Most batterys need at least an hour minimum to be fully charged after its drained completely.
Post back if you need any further assistance. Thank you for choosing Fixya!
Jun 21, 2009 | Samsung SGH-D820 Cellular Phone
Working less than 12 hours
tyr to change ur charge
May 09, 2009 | Nokia Cell Phones
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
LG VX5400 cell phone power problem
try replacing your battery
Jul 29, 2008 | Cell Phones
Hi. My samsung G600 is playing up. In the past half an hour it keeps turning itself on and off. The battery is fully charged and I have turned it on and off myself a few times but still the same outcome....
The problem you have is software related and you will need to send it back to samsung who will sort it out, or if you give samsung a call they will tell you where the nearest samsung repairer is , my local one is in the carphone wharehouse, they told me it would take about an hour and a half , or i could leave it there and borrow a temp phone and pick up at my conveniance.
May 28, 2008 | Cell Phones
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Sony Ericsson W200i Cellular Phone Logo
135 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
