Question about Cameras
I need service on a Rollei 35mm dual lens projector and don't know where to send it
  • 667 Answers
Here is a link to most repair shops in the USA: Acecam
Posted on Mar 13, 2008
SOURCE:
Slide projector help from Rollei- GmbH
What is exactly the projector make and model?
Jul 19, 2008 | Rolleiflex 3001 35mm SLR Camera
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
We have Rollei Projector P37E, where can we buy a slide tray for the same ?
Impossible to find new ones. They only fit this model and haven't been made in decades. Used camera specialists like KEH in Atlanta, GA might have some.
Jul 13, 2011 | Rollei 66 Dual Slide Projector
I need to know where in brisbane I can get hold of globes and fuses for a Rollio P35A slide projector
Any store that sells Osram or Philips can supply the bulbs (globes). Fuses are available from any electronics store. They do not have to be silica filled.
Nov 07, 2010 | Rollei 66 Dual Slide Projector
Kodak 750h slide projector; brand new bulb, but it won't turn on/light up? Could it be the lamp socket? I did open the machine up, and there is a ceramic part; thermal fuse? resitor? or Solenoid??? Not...
If the lamp is new, then your problem is caused either by the lamp socket that the lamp slides into, or the lamp thermal fuse.
The white part over the fan is a dropping resistor, which allows the projector to operate in the "LOW LAMP" position of the power switch.
A factory-trained service dealer can help you locate the parts or (better suggestion) isolate & repair your projector.
Mar 12, 2010 | Rollei 66 Dual Slide Projector
Rollei slide projector
you need to go to a photo shop (not walmart). but you may need the negatives.
Dec 10, 2008 | Rollei 66 Dual Slide Projector
Rollei 66 Dul P projector
I've only worked on one or two of those, with no training in that brand. Good machines but I suggest you try an authorised service shop. here are some links to try
http://www.sl66.com/pg/repair.shtml
In Canada, this company *might* be able to help you. Kominek
405 Yonge St
Toronto ON, M5B 1S9
Phone: 416-977-2132
Mar 14, 2008 | Rollei 66 Dual Slide Projector
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
