Hi dave holte,
It should be through the USB port, I don't think any players nowadays have separate ports for charging. Nevertheless, check if there is any port other than the headphone and the USB, because it never hurts to check. Does the computer recognize the device when you plug the mp3 player into the USB? It might be loose connection as well. Or maybe it is not set to be recognized as an MTP or Plug-and-Play device. Once you have it plugged in, go to My Computer (I'm assuming you are on PC) --> Device Manager and then scan for new hardware changes. Probably then you have to manually install the device and its drivers. But do check for the loose connections. Ask back if it doesn't work.
