Question about Hunter 33202 Humidifier
Cleaning the filter
I lost the book and need to know how and how often i should clean the filter
  • 123 Answers
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Posted on Apr 18, 2008
2 Suggested Answers
  • 123 Answers
SOURCE: need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
What does the ceramic cartridge in the powerpure 3000 humidifier do and When do you need to replace.
PowerPure 3000 Ultrasonic Humidifier
This review says it has a permanent ceramic filter that cleans the water in your tank. Another review said the ceramic filter softens and cleans the water.
Amazon com PowerPure 3000 Humidifier Home Kitchen
That model appears to not require replacing the permanent ceramic filter. Other models have filters that need to be replaced.
Jan 27, 2018 | Humidifiers
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
Changed filter and it still says "clean filter" on the gauge-?reset button
not sure if there is a reset button if not
I would say if the filter was bad enough some of the foreign materials (particles the filter should capture) may have went on down the line.
the "clean filter" indicator is most likely activated by the volume of flow. So when the filter is full the flow is reduced in turn the "clean filter" comes on.
so if filter has been replaced and there is no reset button try backflushing the lines. If the lines have built up blockage your flow will stay low and the "clean filter" will stay on.
on these lines there may be bends and turns most likely to have build up in these areas restricting your flow
clean lines (low air pressure may work easiest)
Mar 03, 2010 | Sunbeam 1117 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Cleaning instructions
nvm :)
Features: Low Maintenance:
* Regulated Release ™ System - eliminates stagnant water while preventing mineral build-up on the wick or filter, which can impede performance in ordinary evaporative humidifiers.
* Dishwasher-Safe, Easy-Clean Base and Tank - with antimicrobial agents molded into plastic parts to inhibit the growth of microorganisms.
* PermaWick ™ - permanent wick never needs to be replaced, saving up to $45 per year in replacement filter costs.
* Top Down Water Dispersion - evenly disperses water from the top over the entire wick to prevent mineral build up that can impede performance.
May 22, 2008 | Hunter CareFree Plus 33222 Humidifier
My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
May 19, 2008 | Humidifiers
Need to clean the filter
Daily Maintenance
1.
use.
Weekly Maintenance
Removing Scale
1.
tear filter.
1.
be damaged.
Hope this helps.
Good Luck.
Dec 01, 2007 | Vicks V3100 1.2 Gallon Humidifier
Hunter 33202 Humidifier Logo
1,161 people viewed this question
Top Hunter Humidifiers Experts
Vernon Taylor
ka4iup
ka4iup
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
