Question about Jenn-Air JXT5830AD Kitchen Hood
No exhaust in ductless mode
Fan operates well but there is no exhaust vented into the room from the slot in the top face plate. Installation instructions reference re-positioning "side panels for ductless operation" but I can't find them. Even Jenn Air tech support couldn't find them. Do these act as a damper to re-direct airflow through that slot? How do I re-position them? Where are they? Help!
    President:
  • 1,304 Answers
They are indeed
you need to take off the filters
you will sede then you need to turn then 90 degrees to vent out
Posted on Oct 05, 2009
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
Screw/nail in microwave housing loud rattle when exhaust fan is on.
A screw that falls into it from the top should be in the vent fan in the top rear of unit. I think you will have to take the unit down from the wall, at that point, either remove the vent blower fan and shake it out, or turn the whole microwave upside down and it may fall out.
Oct 17, 2017 | Whirlpool GH7208XRS Stainless Steel 1200...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
We are in Canada and it has been extremely cold, however we continually are getting error code 10. Is there something we can do as we do not have hot water at all
10 Air Supply or Exhaust
Blockage
Ensure Rinnai approved venting materials are being used.
Check that nothing is blocking the flue inlet or exhaust.
Check all vent components for proper connections.
Ensure vent length is within limits.
Ensure condensation collar was installed correctly.
Verify dip switches are set properly.
Check fan for blockage.
Jan 15, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I would like to know whether the factory blower orientation for MMV4205AA had changed since 2000. Was it changed from top vent to circulating (into the room)? If it did, when did this change...
Here are the instructions for re-orentation of the blower.
The unit is shipped in the room vent configuration. The blower is re-orented for a wall vent.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-011
The page numbers for the manual are changed at the top of the document.
For roof vent configuration:
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-012
Wall plate installation is on page 13
Here are the instructions for the wall plate.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-013
Thanks for choosing FixYa
Kelly
Sep 13, 2010 | Maytag MMV4205 Microwave Oven
Samsung SMV blower installation
Most Microwaves arrive ready to vent back into the room. For filtered air returned to the room it should face toward the front. For top vent, point to the top. for rear wall vent point toward the back.
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Switch/Controller Problem Odd problem and with the price of the control board being $235 and the switch only $58 I need to find out which one is bad: Each switch for the fan and light work fine through all settings (fan; hight, med, low and light bright and dim) IF SWITCHED ON ALONE but if I have the light on and try to turn on the fan (which defaults to MED/pos2) the light will remain on but the fan will make a slight noise then be silent. If with the light still on, then switch the fan to LOW/pos1 or HIGH/pos3 the fan will turn on and the light will stay on and it works fine. If I turn on the FAN first then the light, no matter what teh fan setting, will only do on at the Dim0nightlight setting! I was told that not only does the unit have the centrally mounted Electronic Control Board but the switch assembly also has a circuit board in it so I am unsure how to proceed. I cannot find any troubleshooting guide/test parameters for this unit anywhere and Whirlpool/Jenn-Air were no help. As a side note, the parts guy says that, yes, the front mounted switch assembly is only $58 BUT that the "ribbon Connecttor" can NOT be reused then tells me that the short piece of cheap ribbon is over $300! I gathered after he checked a bit that that price gets you the ENTIRE wiring harness???? WHy can I NOT reuse the ribbon connector? on computer obards one can trim off the penetrated section and reuse it. ANY help will be GREATLY appreciated!!!!! Doug
Mar 01, 2017 | Jenn-Air JXT5830AD Kitchen Hood
Jenn-Air JXT5830AD Kitchen Hood Logo
177 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
