You can remove write protection in many ways .. see some steps in this link http://www.soluzia.net/How-to-disable-write-protection-of-USB-flash-drive.php
Your pendrive has Virus.Format all the data and then try copying or try removng the Virus through a Antivirus..
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
SOURCE: write - protected message when I connect my Transcend 8GB Pendriv
write protection on transcend 16gb pen drive
SOURCE: pendrive is not formateing
look for a write-protect switch or tab...also check the attribute of the file, check if it is read only...you need to remove the read-only if it is set. Usually doing a full format will erase it
