Question about Refrigerators
Freezer The compressor in my freezer tries to turn on but only stays on for about a minute then shuts off. What is wrong?
    President:
  • Refrigerators Master
  • 2,651 Answers
Chances are you have a bead compressor, you can try to replace the starting device (overload relay assy). mounted to side of the compressor, usually about 50-100 bucks. sometimes it works sometimes nada!! and for how long it will work no one can tell. check you manual and see when oyu purchased, most refrigs came with 5 year coverage on compressor assy, costly repair w/o warr
Posted on Mar 13, 2008
Ess25lgmb freezer fan doesnt shut off
Most fans only run when the compressor runs, it must be wired wrong, OR if the unit has a computer control (LED digital display) it may be the main board has shorted, you can try unplugging it and let it sit for 10 minutes, then replug it. ALSO sometimes there are sensors that sense the temurature and will kick on a fan if they are out of parameter, changing sensors if they are malfuntioning can fix this as well...
Feb 08, 2013 | Kenmore Refrigerators
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
Aug 07, 2012 | Magic Chef Chest Freezer MCCF5WBX
The freezer stays at 20 degrees, the refrigerator side is at 38 degrees. Replaced the defrost timer yesterday. Shut off then turned back on til the compressor kicked back in.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2011 | Refrigerators
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 22, 2010 | Woods Freezers
Compressor running non-stop
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Sep 23, 2017 | Amana ARB220ZCS Bottom Freezer...
Freezer compressor turns on for a minute and then shuts off
ur overload chip is triggering, check r134 charge , or start relay, and condeser, otherwise ur compressor might be damage..
Mar 15, 2009 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Mar 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
