Question about Dryers
I'm tring to put a belt on my World pool, Iperial series heavy duty dryer.
    President:
  • 1,314 Answers
Afacing the drier get a small putty knife come about 1 inch from the edge of the drier and push in with the putty knife to release the plastic clip some times this can be difficult pull up on the top at the same time do that on either side till you get the top up then tilt the top back against the wall disconnect the the door switch wires look in the drier to the front panel on either side you will see two 5/16 screws remove them tilt the front panel toward you nd remove the panel put the belt around the drum slide it back to where you can see the old one has been running pull the idler wheel back hold tension on it and put the belt around the motor pulley let the idler pulley up till it engages the belt and reverse dissemble don't for get to plug the door switch back up
Posted on Mar 12, 2008
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
My Frigidaire Galaxy Series Commercial Heavy Duty Dryer does not spin it heats up but doesn't spin. What would be the cause of that?
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Oct 06, 2013 | Frigidaire FDE336RE Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Dryer Belt
your model number is inside the dryer door,you can go to your local appliance part store or to sears.com or repair .com or ebay to buy one-mike
Jun 22, 2009 | Kenmore Dryers
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Idler pully
there has to be a spring on the idler to keep it pulled against the belt
Mar 01, 2008 | Kenmore 62622 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
