Question about LG WM2688H Front Load Washer
Disgusting odor I have tried bleach, vinager &soda, lemon, never close door between loads....I do not seem to be the only person with is moldy problem...My clothes especially towels smell awful
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Posted on Jun 14, 2009
  1. We had the same problem and only with towels. We then tried HE soap in the soap area, Clorox Bleach in the bleach area and Downy in the Fabric softener area, and set the cycle to "Sanitize." The cycle takes two hours but our towels smell great now!
Posted on Mar 20, 2008
    Novelist:
  • 131 Answers
Find a product called Washer Magic.
http://www.amazon.com/Summit-Brands-WM06N-Washer-Laundry/dp/B000LF5VMQ
In addition to the things you mentioned above, Use ONLY HE detergent (the mildew eats leftover soap residue) and always remove the clothes immediately after every load. That's the best advice there is.
Posted on Mar 12, 2008
With the front loaders DO NOT use liquid detergent... since I switched to powder detergent it never smells ..
Posted on Jul 10, 2009
We had this too and only on the towels. We put Downy in the fabric softener area, HE soap in the soap area and Clorox Bleach in the Bleach area and washed the towels on Sanitize--takes two hours, but they smell great and solved our problem.
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have the front load washing machine wm2010cw. The washer just has a foul odor and I can not seem to get rid of it. I have tried using Affresh and had a tech come to see what the problem was but all I got...
Aug 23, 2011 | LG Washing Machines
Odor from front load washer.
I had the same problem. I did all of the above. What worked for me was to spray the tub itself with a mixed solution of bleach and water. Let it sit for a while and run it on a quick cycle unloaded. Also I changed to powder det. with fabric softner in it. I found the outer tub had the mildew and this solved by problem.
Dec 30, 2009 | LG WM2688H Front Load Washer
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Moldy odor
Try running it with just vinager and water no clothes.
Just put about a cup of vinager in it and wash cycle and another cup in rinse cycle.
Vinager is a better disinfectant and odor eliminator than bleach.
Mar 25, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub smells of stagnant water
there sa new product on the market available at at major chains, and also online AFFRESH tabs!!!!!! works wonders for htat particular problem
Mar 08, 2008 | Kenmore Elite 45986 Front Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
LG WM2688H Front Load Washer Logo
753 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
