Question about Kenmore 44072 Front Load Washer
Kenmore 44082 Front Load - Door Leak
I have a slow leak coming from the bottom of the door. The Bellows Clamp Spring is well rusted from about the 10:00 position down to the 6:00 position. I presumed the leak is through the Bellows at the 10:00 position and the water slides down to the 6:00 and then out the bottom of the door.
I see no tears/holes in the bellows at the 10:00 position.
Could the clear door panel not put enough pressure against the bellows to seal when the door is closed? I noticed the lower right hand corner of my door is not flush with the the outer panel. Hinges do not look adjustable.
HELP. Thanks in advance.
  • 2 more comments
  • hoopdaddy Mar 13, 2008
    Sorry, I don't think I understand the question. I opened the door and looked down at the boot and do not see any channel with holes.
    The repair parts list that came with the machine says:
    Door Boot Bellows 1343652000
  • HE troubles Mar 21, 2009
    my washer is a Kenmore HE-2 110.46462500, which was made by Whirlpool 110 from list I have found on the web. I have the same problem and do have the bellows with the three holes at the bottom for drainage back into the drum, any sugestions?
  • robert samples May 11, 2010
    look at the bottom of the boot see if there is a slight channel there slanting down with three holes at the back of it
    President:
  • 1,314 Answers
You did fine several companies built kenmore for sears yours looks like a frigidaire on some models there is a problem with water collecting at the bottom of the door where the bellows or boot is and leak to correct this they came out with a new boot that has a channel at the bottom with three holes in it so the trapped water can drain back into the tub the parts kit for that is 5303937187 now on washers with rubber boots its recommend that you shut the door with a little force to make sure it closes tight against the boot sorry about the letters they came with the part number you might want to call kenmore parts to ask about the boot kit if i was there i could tell you but it looks like a frigidaire to me
Posted on Mar 13, 2008
  • robert samples Mar 13, 2008
    i know but make sure its the up graded one
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Jun 25, 2009 | LG WM-1832C Front Load Washer
Water leak from the front of the machine
Clean off the bottom of the door glass. If hair or lint builds up there, it dose not seal completely and a little water will run down the front of the machine. If that does not solve your problem, you can try moving the spring clamp (which holds the front of the tub seal)so the spring part is moved to the hinge area (a 80 degree move) instead of at the bottom of the door.
Jun 03, 2009 | LG WM1815CS Front Load Washer
Changing the bellow on a duet
Tilt the machine back to create more space between the front on the door and the outer drum. Remove the screws for the kickplate and remove the kickplate for easier access. Open the door and remove the spring clamp holding the bellows to the door opening lip. Push the bellows into the drum to get access to the outside/ rear of the bellows (where it connects to the drum). There you will find another clamp which you loosen/ remove with a socket. Some models have an overfill tube on the top of the bellows (remove it from the bellows). At this point you should be able to completely remove the bellows.
Align the new bellows to the outer tub. Attach and tighten the inner clamp (be careful not to over tighten and periodically check the bellows and clamp placement as you're tightening to make sure it doesn't slip off). Attach the overfill tube (if equipped). Lay the machine back to level and install the front of the bellows to the door opening lip. Re-install the spring clamp by starting at the top and working your way down both sides (may be easier with 2 pairs of hands). Be careful not to overstretch the spring on the clamp.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top.
Let me know if you need more assistance.
Apr 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to change bellows on Kenmore front loading washer
First remove the bottom kick plate at bottom. Then tear off the front of the bellows from around the door. Inside there is a big hose clamp holding the inside if it. Remove completely.
Now,put the inside on first, Tightening the inside clamp. Easy so far, right?
My trick to the outer spring:put a little liquid detergent or soap on out bellow where spring attaches,start at top and work it down and around, use needlenose pliers to help with hard part. Good Luck.
Mar 13, 2009 | Washing Machines
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
How do I replace door lock/switch assy in kenmore 44082 washer
easy repair, somply open the door, and l;ook behind the rubber boot, youll see a metal band holding it to the fornt of the machins( spring loaded at very bottom) roll the "clamp"wire off andremoveth righthand side of the boot, youll need to unscrew trhe 2 phillips screws holding the latch assy on nad it will slide right put, probly 3 connectors( youll have enough wire to almost pull all the way out.. replace with the new latch(wires only plug into correct spots, you cant do it wrong). resecure the latch and roll the rubber boot back over the front lip. rescuring the metal clamp may take a little patience, but get a third hand if available.. starting at top strecth over both sides and snap spring over the bottom. easy repair take youtime youll be fine!!
Jan 25, 2009 | Washing Machines
How to replace the door bellows seal ?
Unfortunately the service manual will not tell you how to replace the bellows.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top. Enjoy clean clothes!
Dec 19, 2008 | Whirlpool GHW9100L Front Load Washer
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
Kenmore 44072 Front Load Washer Logo
433 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
