Question about Viking Kitchen Ranges
Viking Range Mod.# VDSC 485-6GBK. Can not get oven doors to latch to go into Self cleaning mode.
SOURCE:
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
Boogan
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
[email protected]
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
Posted on Apr 08, 2009
SOURCE: Oven door still locked after clean cycle
Take off the burner platform over the oven. Slide out the drip platform completely. Remove the access plate over the oven (Use a Phillips head sideways in a locking wrench to loosen screws). Using a long screwdriver slide the locking arm to the left of the oven as you face it, jiggle it a bit and it should release. I hesitate to clean the oven again but at least I now know how to release the lock and I saved $150.00 from my local appliance repair bandit.
Posted on Jan 01, 2010
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Viking model #vdsc365-6bss door will not open
I guess it would be stuck in self clean mode...a latch above the oven door handle...does this on have a self clean..should have asked that first...
May 26, 2014 | Kitchen Ranges
Door lock does not engage and the cleaning does not start
Hmmm... A question about your kitchen range in the refrigerator forum??? Won't find much here.
Mar 03, 2014 | Viking Kitchen Ranges
Dec 31, 2009 | Viking Kitchen Ranges
I cant get my viking 30inch electric range to self clean. it has a self clean spot on the knob and on the temperature knob but when both in place nothing happens.
You might need to lock the oven door to get the self clean to go on. My stove had a lever which locked the oven door when you pushed it sideways. It was in the middle above the oven door, in the gap... Hope this helps!
May 06, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Self Cleaning Latch Stuck
You have to basically split the stove apart to replace the self clean latch assembly. Not easy I don't think. I would get service. But tell the techs not to overdo it on the price and try to get the part yourself from Viking. Good luck.
Apr 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Good Morning: The self cleaning mode engages, locks the oven on the bottom, but does not clean. On the top, the latch does not engage at all on the self cleaning mode. What to do?
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
SO
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Mar 27, 2009 | Viking DEDO205 Stainless Steel Electric...
Oven not working -makes a buzzing sound when turned OFF!
You just need to adjust your door latch assm. Try putting a little oil on the latch and arm. The sound you hear is the solenoid trying to pull the latch arm all the way back to lock the door. Even though it is pulling the arm back and the door locks it may not be all the way back. A little lubrication will fix the problem.
Dec 20, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
94 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
