Phillips 60 inch tv
Double lines on the bottom of my 60 inch phillips tv. what can i do? thank you
    President:
  • 1,779 Answers
There is nothing you can do to repair the convergence problem it sounds like you have. If it is the older PTV set with crts it will probably cost $200.-$300. for the average repair of this nature.
If it's a DLP model, no convergence in those. Most likely a Light Engine. $500.-$800
Posted on Mar 12, 2008
My phillip tv has started showing a double picture
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 11, 2010 | Philips 60PP9202 60" Rear Projection...
My phillips tv has a green line at the bottom
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 60PW9363 60" Rear Projection...
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
Jul 18, 2009 | Philips 60PP9200D Television
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
