Question about Xante Ilumina Digital Color Press Printer
Ghosting Not a problem - I'm considering buying this printer for my print shop and wondered if I ran a letterhead could it be run back through a laser printer without ghosting as most lasers do?
  • eror May 17, 2008
    registration
  • Anonymous Mar 31, 2014
    repeating, ghosting
No. you can not run it back through a laser printer. the toner will melt in your customers printer. Tried this, and reprinted using offset.
Posted on Jul 16, 2008
When printing on letterhead, my documents have a slight "copy" of the letterhead in various locations throughout my document.
Your preprinted letterhead is sluffing off during the fusing process. Have your service tech adjust the fusing temperature.
Aug 12, 2014 | Brother MFC-8860DN Printer
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
HP Color Laserjet: ghost images, both black and color print jobs
Hi
sounds like either you fuser rollers need to be replaced or you need a new drum and cleaning blade, those 2 items will cause ghosting,
good luck
Jan 28, 2009 | HP LaserJet 2605DTN Color Printer
Printer is ghosting - I have changed power supply
Might be your transfer roller. I would try some laser cleaning paper and run that through a few times. If that doesn't work, I would purchase a fuser maintenance kit which will have the rollers as well as a new fuser.
Dec 15, 2008 | Brother HL-2040 Laser Printer
Where can I get a 6L repaired in NJ?
With the low cost of printers that are better than the 6L I would not waste the money to repair
Sep 27, 2008 | HP LaserJet 6L Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
"shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Jan 02, 2008 | Brother HL-2040 Laser Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
165 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
