Question about Canon imageRUNNER 5570 Copier
RICOH FT7650 I GET MESSAGE TO CALL SERVICE TO EMPTY USED TONER BOTTLE? CAN I DO IT MYSELF OR RESET SOMETHING? i GOT THE MESSAGE WHEN I CHANGED THE TONER BOTTLE. ANN
  • vbaker1890 Mar 31, 2009
Service fixed it today.
thanks anyway
Posted on Mar 13, 2008
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
How do i clear the toner amlmost empty message on ricoh mpc2800 , it still appears after i added toner in the bottles.
because the bottle is what the machine is looking for it cant tell that there is new toner in the bottle, it knows its new when the bottle is replaced go to store and buy a new bottle with toner in it.
Jun 12, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
Pls we need your help with ricoh affico printer 3224C the screen of it write this message : used toner bottle setting error used toner bottle -2 is not set properly. open the part as shown and set the...
look my friend used toner means that this toner is disposal or exhausted ok ensure that empty exhausted toner not mean fresh toner are yo ander stand
Jan 12, 2011 | Ricoh Aficio 1035 Copier
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh lw310
Unless you care to risk damaging the copier, I'd recommend having a service tech empty the used toner bottle.
Accessing it requires removing two covers, loosening a leaf spring, and removing the toner overflow sensor before you can remove the bottle. Then you have to reverse the procedure.
Jul 09, 2008 | Office Equipment & Supplies
Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Jul 03, 2008 | Ricoh Aficio 1035 Copier
Canon imageRUNNER 5570 Copier Logo
old marine
old marine
