Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Hot temprature all product in side the refrigerator was melted, i took of everything from the refrigerator let it dry and cool-of and then i start it again and it blowing hot air in both cameras... what could it be?
  • robert samples May 11, 2010
    see if the compresser is running or just buzzing and clicking and see if there is a white rely on the compressor where the wires go in white plastic box
  • 828 Answers
Your problem may be related to the condenser on your refrigerator. I believe the bottom plate under the door may say to clean every six months. If it has not been cleaned it will cause the refrigeration system to overheat and cycle the compressor off on its thermal protector. If the compressor located in back behind a fiber panel is hot but not running the problem may be solved by cleaning throughly. If after a shut down of 30 minutes or so it still fails to start , but just hums and clicks the problem is in the compressor itself.
Posted on May 13, 2008
Fridge isnt cooling
is the fan run on the compressor? you might need only starter unit to fix the compressor...
contact me at
Dec 30, 2009 | Frigidaire FSC23F7D Side by Side...
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water was dripping in bottom back of freezer. Coil was red hot and was sizzling as water hit it. Where did water come from? Never seen this before. I actually heard the dripping sound which alerted me to...
What you observed is the automatic defrost system at work. There is a heater coil (the red hot tube you saw) that comes on at various times to melt frost off of the evaporator coil. This cycle generally lasts 25-35 minutes and then the refrig will start back up and resume its normal cycle.
The water that melted off the coils drips into a drain pan under the unit and will evaporate from the heat and air movement from the compressor. Everything you expereinced is normal and nothing to worry about. thanks Peyton...
Apr 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer freezes up causing the refrigerator side not to work
you probably have a bad defrost timer. This item will turn on a hot coil to melt the ice when it needs melted. If you coils are solid ice then the cold air cant travel to the refrigerator side to cool it. This air is moved with a fan and the ice blocks the movement. Melt all the ice with a hair dryer and put the cover back on u will be good for a bout a month and if defrost timer is bad it will clogg again.
Jan 09, 2009 | Admiral 26 cu. ft. Side-By-Side...
yes on top of the compressor
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire frs24zrh refrigerator not cool enough
Check out need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
GE side by side Refrig. with evaporator iced up solid.
Yes ill be glad to help John. Your refrigerant level is fine. Remove the motherboard axcess panel on rear of refrig. Locate 3 wire blue plastic connector on bottom of board. Wires are labeled Comp, Line, Def. Jump Line to Def and see if heater gets hot. If nothing happens than replace the heater. Let me know what happens.
Dec 04, 2007 | Kenmore 91365 Compact Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
