Question about Lands Phones
We are a small, private elementary school with an NEC Electra IPK system. Every time daylight savings time starts or stops our phones are out of whack. I have contacted both the equipment vendor and Sales@.E System Sales, Inc and received no help. Matrix, the equipment vendor is willing to make a service call to program. I think there must be some way for us to do this change ourselves. Please advise. Thanks.
  • 2,326 Answers
There seems to be some more info HERE.
Posted on Mar 12, 2008
  • 19,396 Answers
It is quite difficult to find detailed info on your device, however it should be possible to chane daylight savings settings. I will check some documentation and come back to you
  • 2 more comments
  • Ginko
    Ginko Mar 12, 2008
    One way to change daylight savings time, as shown in this document, it is reprogramming phone memory. I think there must be an easier way to just disable the setting from one of phones menus.
  • Ginko
    Ginko Mar 12, 2008
    Here is the programming manual from nec, it contains all the instructions to customize your phone and eliminate this problem. I will try to extrapolate ant synthesize the contents related to your problem, give me some extra minute.
  • Ginko
    Ginko Mar 12, 2008
    HOW TO ENTER PROGRAMMING MODE
    To enter programming mode:
    1.Go to any working display telephone.
    In a newly installed system, use extension (port 1).
    2.Do not lift the handset.
    3.Press Speaker.
    4.# , # , .
    Password
    5.Dial the system password + Transfer.
    When you are done programming, you must be out of a program's options to exit
    (pressing the Answer key will exit the program's option)
    When in programming mode search for program 10 (daylight saving setup), once you are there set 'daylight savings mode' value to 0 and it is done.
    Here follows original description from manual:
    Program 10 : System Configuration Setup
    10-24 : Daylight Savings Setup
    Level:
    IN
    Description
    Use Program 10-24 : Daylight Savings Setup to set the options for daylight
    savings. As the telephone system is used globally, these settings define when the
    system should automatically adjust for daylight savings as it applies to the region in
    which the system is installed.
    Input Data
    Item
    Related
    Item
    Input Data
    Default
    No.
    Program
    01
    Daylight Savings Mode
    0 = Disable
    It is a bit tricky to explain, but it shouldn't be too difficult to put in practice. Give it a try, I think it is the only way to fix it.
    Regards
  • Ginko
    Ginko Mar 12, 2008
    Recapitulating, Get in programming mode, reach program 10-24, set 'Daylight Savings Mode' value to 0. Done
How do I change the names on the stations?
it depends on your type of phone system. On an Elite IPK system you need to enter program mode from x100 or x101 then goto function 4/18 per port and assign names. transfer key saves.
need help remote billable support at www.ldtsnj.com
Mar 31, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
Mar 04, 2015 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i make the nec electra professional phone not ring
I think you have change its internal setting so reset your phone again so its again setup your phone and your problem has been removed like phone ring.
Nec sv8100 IPK DTerm phones Inlinecom
Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change from lunch to day mode
These phones work on about 8 NEC systems, but for a PRO II, an Elite, and an IPK, the standard code is Feature,80, Feature from one of the two main reception extensions. Don't know the code for a 2000, 8100, or IPK II.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
NEC Electra Elite IPK
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
174 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
