Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Nat change How do i change my nat in a step by step gide
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Do you have your manual? Do you need one? Are just looking for someone to tell you the step by step process of doing it?
    Scholar:
  • 89 Answers
Hello, The easiest way would be to do a google search for "Step by step NAT configurations for {Model #}". You'd be surprised what may come up. Give me a brand & model number & I'll see if I can Help. Thanks.
Posted on Mar 17, 2008
SOURCE:
How to config my belkin n300 to change nat to open in xbox live
Belikin has one DMZ IP option in the web admin.
Go to Portforward dot com for step by step instructions. Also refered to as virtual servers on some routers.
Dec 29, 2012 | Belkin Surf N300 Wireless N Router
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
How to change a NAT to open?
Here is a direct link to ehow this will tell you step by step on how to change the NAT settings hope it works good luck
http://www.ehow.com/how_6017590_do-change-linksys-nat-settings_.html
Sep 30, 2010 | Linksys Wireless-G Broadband Router
Change NAT type from strick to open FOR XBOX
1)NAT STRICT
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox
Step 7: Get the IP Address of the Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Apr 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cant get to the page so i can change my NAT type
mine pops up when i type in www.router.login.net
give that a try.
and heres step by step instructions for changing the Nat type for xbox360 i used to change mine in case you need help.
http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360.
hope this helps
Jan 16, 2010 | Microsoft Xbox 360 Console
I want to change my NAT settings on my router
Step 1 : Check the IP Address of the PS3 And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of thePS3 in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Mar 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Changing the NAT typer from "moderate" to "open"
Follow these steps to use this solution:
  1. Use the no ip nat {inside | outside}command to disable future translations from taking place.
  2. Use the clear ip nat translation command to clear IP NAT translations.
  3. Change the NAT configuration.
  4. Restore the NAT {inside | outside} arguments with the ip nat {inside | outside} configuration command.RICHARDM69
Dec 15, 2008 | Linksys Wireless-G WRT54GS Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
