Upgrade processor on ALI 1541 motherboard
I have an IBM Aptiva 2153 E2U with an AMD k-6 2 333Mhz processor. I want to upgrade to AMD K-6 500 Mhz. I have plugged in the new processor but I think I have configured it wrong. When the system boots up it registers as 333 Mhz.
Please advise.
  • 807 Answers
May need to be configured in the Bios, but also some older boards had processor adjustments on the motherboard, either with a block of little white dip switches, or with jumpers that you remove or replace depending on the processor. Some times the settings for the processor are printed on the board too. Are you sure the motherboard can take a processor up to 500MHz.
If you don't have the manual for the motherboard have a look on it for the make and model number and search google for it. If it is available it will probably be an Adobe pdf file so make sure you have Adobe's Acrobat reader.
Posted on Mar 12, 2008
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Thermal faillure, processor is problem. how price? this processor?
Desktop? Laptop?
What manufacturer of motherboard?
What model of motherboard?
Intel or AMD CPU?
What model-number?
Search on www.eBay.com for a compatible CPU.
Jun 07, 2011 | Dell Pentium 3, 500 MHz Pentium III...
IBM Aptiva E 245 , can you tell me what the processor speed is?
Yes I can tell you its speed
Processor is AMD K-2
Its processor's speed is 401 500.
Please feel free to contact me again.
Thanks.
Have a great day.
Sep 08, 2010 | IBM Aptiva E 245 (2170245) PC Desktop
I want to upgrade my Cerelon 500 MHZ Processor into intel Higher MHZ
Hi, the best way is to put your motherboard details into a google search, find the best proceesor for your motherboard. Then ebay would probably be the cheepest place to purchase.
Hope this helps
Jul 24, 2010 | Hitachi Pentium III , 500 MHz...
Re upgrade, memory, speed etc?
Upgrade the RAM/Memory? Yes to the maximum *********** Bord will support.
Upgrade the Processor for more speed on a 9 year old Mother Board? Probably not worth the trouble.
Apr 20, 2009 | IBM Aptiva 2193 PC Desktop
CPU upgrade
Your motherboard has a good support for various Processors. If you want to go for the latest then you can go for Palamino core Athlon 4.Its compatible all the KV7 series boards but all you have to check is "Till WHAT clock speed can your board support?" .
Regards,
Sai.
Jul 10, 2008 | AMD Duron , 700 MHz Processor
EliteGroup K7S5A (does not say pro on the board)
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm.
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Jan 13, 2008 | EliteGroup K7S5A Pro Motherboard
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
Diagram of motherboard wanted
Based on your post/description, you would want to do 2 things: 1) upgrade a Cyrix and 2) install LAN capability.
#2 is easier, all you need is a PCI LAN card with the right drivers for your operating system and you should be set to go;
#1 is trickier...
If you are referring to a Cyrix MediaGXm motherboard, at most that you can go up to is a 300 MHz CPU and hopefully a max of 256Mb of memory depending on the motherboard version.
If you are referring to a Cyrix MII-433 processor which ran at 300 MHz (100x3), hopefully you can try replacing the processor with an AMD K6-2 500 or higher, that is of course assuming that the motherboard is compatible (FSB, VCore voltage, multiplier). You should take into consideration that other than the MII-433. most Cyrix CPUs run at 83 MHz bus in a (Super) Socket 7 motherboard and technically is extremely overclocked (PCI bus running at 41.5 MHz). You should meticulously check the various jumper settings to accommodate your upgrade CPU. For stability, perhaps you should choose an Intel 266 with MMX, for speed AMD K6-2 500. This is of course if you can still locate such processors and appropriate memories.
Good luck and kind regards.
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
