Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Flash in Canon SD630
Flash doesn't work in canon sd630 ... I have replaced the LCD screen in it and now flash doesn't work ... anyone has any idea what might be wrong and how to fix it ??? ... thanks in advance ...
s
  • seba11 May 09, 2008
    Well I took the camera apart and try to find any loose connections however didn't find any ... anyone has a picture of what could have gone wrong ... again i replaced lcd screen in canon sd630 and now the flash doesn't work ...
    s
  • 477 Answers
You might want to check the wires on the flash tube. or it could be the flash circute. most of the time it is just a loose wire.
Posted on Mar 12, 2008
SOURCE:
Canon SD630 any sd card i put in it over 2gp says memory error
The SD630 works with MMC and SD cards, which max out at 2GB. Larger cards are actually SDHC cards and will not work in the SD630.
Sep 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
Broken screen
If the camera is fully functional other than the screen, then yes the LCD screen can be replaced, you can order the part yourself from a Canon dealer if you wanted to do the job, or let them handle the repair with an estimate.
Jan 25, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon ixus 65 - when taking a shot without the flash on, a red camera icon appears on screen and the shot is usually blurry. Why?
When hand-held shooting, shaking will cause blurry. So when the shutter speed below 1 / 60 second the vibration warning will appear, open the flash, up shutter speeds, vibration warning disappeared.
Jan 08, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
The flash doesn' work
Hi
Either your flash unit is defective and needs to be replaced, or the mainboard is defective and causing the flash to not work. The only way to know is to start with the flash and replace it, if that doesnt work its the main PCB.
We are an affordable digital camera repair business, if we can be of any assistance with the repair please let us know!
Good luck from Darntoothysam com
Thomas
Oct 25, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon A 630 no flashing
Right now Canon's support section for their website is down.
What I'm looking for is to see if the flash was turned off by the control panel accidently. Most digital have a setting to turn it off.
Typically if the camera needs a flash and can't give you one you will get a warning message on the screen. If thats whats happening, then the sensor is working.
Sometimes weak batteries will cause the flash not to work because there may be enought current to run the screen and the shutter but not enough to run the flash at the same time. If you say the batteries are fine then that probably isn't the case.
If you have the book handy you might want to check the control panel settings and find the flash controls.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
LCD replacement
The SD600 instructions should be pretty close. Some other examples of LCD screen replacements from the SD series are listed here:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Feb 04, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot SD630
I would definately not "finish" breaking it :)! There are places you can send your camera to have it looked at, and it might be something as simple as a dislodged cable.
This site can do an LCD repair, or can just look at the camera and give you an estimate if you need -
http://www.darntoothysam.com/servlet/the-227/Canon-SD630-LCD-Repair/Detail
Nov 28, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Bright White Screen
Most likely either your LCD has gone bad or the cable has either shifted. Even if the LCD is pure white, the LCD can still fail or be bad.
Here is a link to a guy who does repair and replacement for LCD, and also sells the LCD if you want to replace it yourself.
http://www.darntoothysam.com/servlet/the-228/Canon-SD630-New-LCD/Detail
Nov 11, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
