Boating Logo
I have a 1986 mercury 115 and need to replace the trim motor, how do i get it out/
1helpful
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
How do I replace the trim tilt motor on my mariner 90
most of these will come off if you lift the engine to fully up and lock the lever up to hold it there ! Then you can access the trim motor , clean off around it then undo and remove the motor after disconnecting the wires near the carbs !
I broke the driver side outdoor handle on my 1986 grand marquis mercury. How do I replace it?
 Buy a replacement handle. Once you have it remove the door trim, remove the screws that hold the handle, unhook the command bars by rotating the handle and take it out. Mount it the opposite way.
2helpful
2answers
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 • Boating
3helpful
3answers
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
