Question about ViewSonic VX2235WM Monitor
No signal analog
I installed a new video card so I could get the correct resolution for my monitor. Now when I start up my computer all I get is "no signal analog". I am not sure how to switch to digital.
    Novelist:
  • 138 Answers
Press the front screen button that has an arrow. It will be switching from analog to digital and digital to analog if you press it again.
Posted on Mar 15, 2008
Auto adjustment for resolution won't stay at recommended setting
Linda
hello, for some monitors, when change resolutions take seconds to change, automatic, others have to save them. or your signal if analog, HDMI, or digital try to compesate the screen signals,
when use automatic adjustment, the monitor set for the scale designated in your video adapter.(video card)
Carl
Dec 05, 2015 | Gateway HX2000 20" Monitor
Hp monitor 2031s does not scan signal from gateway gt5432...
Go back to Dell monitor. Remove any video drivers from hp.change video resolution both in windows and in video card settings to standard 1024 x 768 (yes it will look horrible) then hook up hp monitor. Don't install drivers if prompted get them from hp website then adjust resolution through video card settings after drivers installed which probably require restart.
Dec 01, 2013 | HP Computers & Internet
Monitor says Analog RGB 1024 x 768 / 85 Hz Out of Range
install an AGP card into an AGP slot. use 8X AGP card then you can see high resolution because internal display card does not support to high resolution
Apr 02, 2010 | Xerox XR619DW Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
It will say no signal
It would be helpful if you had some more detail to this. However if it's saying no signal, and you're sure that that either the VGA cord is securely connected at both ends, then you may want to check the back of your PC to see if there is another video card installed, and try using that one. I've seen this happen thousands of times.
Mar 06, 2009 | Computers & Internet
CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Jan 23, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I have just installed a crucial x1600 pro graphics card,when i fired up the computor the monitor displayed multi coloured vertical lines and a box appeared saying it was in analog mode, how do i configure...
change cables on card you should have two ports on the card one for analog and one for digital and the cables are different check the ends of the cables digital and analog are different configuration.
Dec 31, 2008 | Computers & Internet
Cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Jun 04, 2008 | ViewSonic VX2235WM Monitor
ViewSonic VX2235WM Monitor Logo
2,118 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
