Question about Toshiba 35AF44 35" Rear Projection Television
Picture loss! Picture disappears to a very thin line after watching a few minutes. Turn TV off and let it cool down for few minutes and picture comes back ?
  • 67Swede Mar 13, 2008
    Thanks Crikett!
    I will have that checked out.
    President:
  • Toshiba Master
  • 1,779 Answers
It sounds like cold solder joints on the vertical IC chip. Not a major deal. The entire board should be looked over for other joints becoming cold.
Posted on Mar 12, 2008
Disappearing picture!
Check and replace damaged components; or, check for any loose solder terminal/s at its vertical scan output section circuit. Gopakumar Gopalan Google
Feb 23, 2014 | Jensen TS2750J TV
Toshiba cf32h40 started last week the pic would go down to one thin line i would hit it on the side and it would come back ,but now thin line comes back when i hit and then goes away so i took off the back...
that silver box is called TV tuner (see picture ) ............ but in your case that is not the problem ......... after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so that silver box ( TV tuner ) is not the problem because when it gets deffective then you will get picture that comes when tv is switched on ---- usually it will be blue screen ......& also if you connect dvd you will get picture normally ...only thing is that you won't get picture from cable or antenna .............. vishnuswamy_25.jpg
Sep 01, 2011 | Toshiba CF32H40 32" TV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
SANYO TV Picture
I just bought a new Sanyo DP19649 and we can watch it for about 15 minutes then the screen goes black but the sou nd stays on. We have to turn it off and turn it back on to get the picture back for another 15 minutes-then it's the same thing all over again. The sleep mode is off and it isn't on automatic shutoff.
Jul 21, 2009 | Sanyo Televison & Video
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair shop.do not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Tv problems
You need to do self diagnosis test first to see what area it is in.
Oct 24, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Toshiba 35AF44 35" Rear Projection Television Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
