Wheni try and connect to the internet it says it can not find my modem
  • Nico Ranan May 11, 2010
    what is your connection? are you using dsl?
    you can change the settings from your internet explorer. dial up settings to no do not dial a connection.
    Sergeant:
  • 349 Answers
Go into device manager to see if the modem is in the list (it should be),if you see a yellow exclamation mark next to it ,it means their is a problem with it .if so right click on it and select re install driver or update driver, this may fix the problem
or
go into control panel ,double click modem icon, then select modems tab, you should see your modem in the list .
(if not the driver has not been installed or modem has died) ,
if you see it,
double click it and then press query modem,another box should open and it will show what functions the modem has or does not have ,
if you see this ,then the modem is physically ok
hope this is of help
Terry
Posted on Mar 17, 2008
  • terry Mar 17, 2008
    continued:
    if its physically ok then its a driver problem.
I am trying to reconnect to the internet I put a new modem in for my internet service trying to connect my router to my ps3 and it won't let me can you please tell me what i have to do. Thank You
I see that you have replaced you modem. Have you tried connecting your pc directly to the modem? If you do not have any internet connection when connected directly to the modem, you have to call your Internet Service Provider to setup your new modem. If you can access the internet using your new modem then there is a problem with the router. You have to re-setup your router to make it work.
Apr 04, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
Says thers a connectivity problem in modem, access point. internet getting to the modem and the computer is connecting to the modem but there is no internet connection.
try to uninstall and reinstall drivers of your modem.
then try to ping any website on command propmt windows.
Hope this will resolve your issue
Oct 20, 2009 | Computers & Internet
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Wireless is connected,but no internet
hey dear,
thanks for your time.... now, as i understand you correctly.. even though you seem to be connected ot the internet wirelessly, you are not able to pull out webpages right?
Try to power cycle the modem.. turn off modem and the computer for about 5 minutes... then try to power it on.. wait for the lights on the modem to turn green and then try to connect... you should be connected. good luck
Got forget to rate me....... take care.
Oct 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
SS4100 modem moved to another computer, Internet LED light not on
turn off the PC and the modem. connected the modem to your IPS (Internet Provider). using a ethernet cable in the port marked WAN. connected another CAT5 cable from any of LAN port to your PC. turn on the modem first then your PC. waite for the PC to boot up. You should have Internet access. unless you Internet Provider need to configure them modem.(dependend on who is your Internet Privider).
Oct 23, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Cannot sign in
There is a possibility that the router is not configured correctly. To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | NetGear WGR614 Wireless Router
Linksys issues
It's clear that the router has lost its connection through the modem since there are no computers that can get online through it. Either the router lost the right settings or the modem is not online. have you tried to bypass the router and try the internet through the modem and check the internet connection? What is the brand or the model of the your modem from verizon?
Jul 21, 2008 | Computers & Internet
Every time we try to use the internet it says unable to find server, if we unplug the ntl modem and plug it straight back in the internet connects how do we solve this
sounds like the internet connection is not setup to Ur modem. When u unplug it redetects the modem and connects. try uninstalling the modem from the control panel - system - device manager. keep the modem connected and reboot. U may have to use control panel - add/remove programs any programs the modem cd installed. on reboot use the modem cd only to get the driver and let windows control the modem.
May 26, 2008 | Computers & Internet
Internet Connection drop outs on Belkin ADLS2+ modem router
Try to call your internet service provider. They should most likely resolve your problem. Or, disconnect everything. Plug the cable wire to the back of your modem. Give it 30 seconds. Plug in the ethernet cord from your router to your modem. Plug in the power adapter to your modem and give it 1-2 minutes to start up. Next, Plug the power to your router. Give about 1 minute. Go onto your computer and hit the start menu, go to the control panel. Look for internet connection and click on it. Find you internet connection, right click, and hit properties. Click on TCP/IP. Make sure your settings are on automatic. Then try your internet.
Mar 22, 2008 | Belkin (F5D7633UK4A) Wireless Router
Computers & Internet Logo
David Payne
David Payne
